Results 1 to 7 of 7
Thread: removing standard VS speakers.
    HSV VT GTS
    Dec 2008
    Default removing standard VS speakers.
    i have searched but couldnt find anything really like a guide to removing the front door trims and how to remove/replace the rear parcel shelf speakers in a VS sedan. can someone help please?
    sorry for the trouble
    Bite off more than you can chew, then chew like hell - Peter Brock
    wl caprice
    Apr 2008
    hey mate not sure if there is another thread either but here we go..
    take out back seat---two ways to do it
    proper way,put fronts seats all the way forward (taking out the part you sit on 1st) use your knees and some brute strength push down then towards the back in kind of 1 motion,its a bit of a pain but you will get there. then do the other side.
    there are only 2 hooks 1 on each side.
    dodgy way --- put your hands between backrest and seat and reef the seat out , it will still be in the hooks but a bit easier to get them out.
    just for the record i prefer to do the 1st way!
    once the base is out i think its only 2 bolts at the bottom of the seat to take the back out ,once the bolts are out you just have to lift it towards the roof as they sit on locating hooks.
    the rest is pretty easy remove the clips in the shelf and it should just wiggle out.
    then you have your speakers.
    NOTE.... i have only done this on a car with no brakelight in window so you may have to take that out
    all out and new speakers in and back together should be around an hour or so, smokos and cans included!!!!
    good luck and let me know how you go or you need any other advice!
    nige(skitzn)
    im schizophrenic and so am i
    196.4rwkw 100% stock
    http://forums.justcommodores.com.au/...l-caprice.html
    wl caprice
    Apr 2008
    sorry i didnt see you needed front as well!!!!!!!!
    quite a lot of screws for front doors.
    door lock--- take out the red bit with a really small flat screwdriver or a test light then lift it out.(and the screw behind it)
    handle(the bit you pull to close door)--- front little panel just pops off and 2 or 3 screws hide behind it.
    the vent bit--- there are a few screws in this about 5or 6 i think , some are hidden and you may have to take the vents out to find some.
    handle--- i think there is 1 hidden in there (bit you open door)
    then around the outside you just gently pull all the way around as they are push in clips.....dont pull to hard or you'll break the door trim cardboard.(you will see what i mean once they are off)
    then once trim is off you can get to your speakers.
    P.S. its been a long time since i have done this so although its fairly accurate i may have missed something so take care in doing it.
    again let me know how you go and good luck
    hsvpunk's Avatar
    hsvpunk is offline volunteer firefighter
    vy ss II M6
    Jan 2007
    Mornington, Vic
    as nigel said. Front has 3 screws long bottom trim, 2 in the handle part, i think 4 in and around the air vent. and 2 clips that slide/pop into a cpl of gaps on the right hand side of trim.
    Rear is abit of fun, i didnt take my seats out for mine though. But same idea as Nigel.
    dont worry, il start a ride thread soon.
    HSV VT GTS
    Dec 2008
    thanks for your help guys, very very helpful. all done now, replaced all 4 speakers!
    thanks again guys!
    VUII SS
    Mar 2008
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Quote Originally Posted by Tony. View Post
    Did you disconnect teh battery to change the front speakers??
    Why is that needed?
    150db in a commodore =
  1. Removing Standard Holden CD Player
    By eagle13 in forum Car Audio
    Last Post: 05-05-2009, 09:33 PM
  2. Standard speakers sydney
    By Torquative in forum Swap / Wanted to Buy / Trade
    Last Post: 20-10-2008, 09:40 PM
  3. standard speakers
    By Torquative in forum Car Audio
    Last Post: 08-10-2008, 06:10 PM
  4. VR statesman standard speakers
    By ssilent11 in forum Car Audio
    Last Post: 20-07-2006, 06:24 PM
  5. Removing Standard vy grill
    By HELLBOY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-02-2006, 09:30 PM
