Results 1 to 10 of 10
Thread: Tweeter Positioning
    VZ Acclaim
    Jan 2009
    Default Tweeter Positioning
    I am now at the stage of installing my new sound system (in a VZ), but I have hit somewhat of a hitch that I had not considered. According to JL's mounting instructions, the tweeter should ideally be located within 8" of the woofer.
    Previously I had just assumed that I would simply mount them in the stock position, however having paid the extra $$$ for the vr600's to get better sound quality, it seems a waste to mount the tweeters in a poor position.
    My question, where would you recommend is the best place to mount the tweeters? If need be I am happy to hack and slash away at the door trim to make a suitable mount.
    Cheers, Dave
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    the pillers where the seat belts are mounted, using the brackets that should have come with the tweeters, cut a round hole the size of the tweeter and mount it flush in the piller, giving you a nice high pitch sound pounding into your ear drum , thats how i mounted mine anyway, in a vt tho
    ryno_vrx's Avatar
    ryno_vrx is offline Donating Member
    VR HSV enhanced Berlina
    Nov 2008
    Mirani
    two other good places are the usual on the door near the side mirror and in the vent on top of the dash near the front windscreen, thats where my new alpine type r tweeters are mounted and they sound sweet
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    Quote Originally Posted by sxc_sound View Post
    thats the most dumbest place to put them
    get a holesaw and flush mount them on your door trim will look good and sound good or factory location is fine sound bounces off window
    VZ Acclaim
    Jan 2009
    Thanks guys, the other thing I forgot to ask is, where should I mount the crossovers?
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Crossovers in the dash.
    My tweeters are on the kick panels, sounds much better than the stock position or the sail panel near the mirrors.
    sxc_sound's Avatar
    VT Series 2 S pak
    May 2008
    Parkdale
    my cross overs are in the kick panels, and the tweeters on the pillar is a good idea imo, makes the sound more home theater surround sound style, but each to their own i guess.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    The B-pillar a ridiculous mounting location for tweeters... The sound from the tweeters is meant to come from the same location as the woofers and they're meant to be as close to equal distance from you as possible. If you put the tweeters on the B-pillar, on is right next to your ear and the other is all the way on the other side of the car, not similar distance at all.
    If you want surround sound, you put your front speakers in the front and your rear speakers in the rear
    sxc_sound's Avatar
    VT Series 2 S pak
    May 2008
    Parkdale
    Quote Originally Posted by StoneX View Post
    if you put them in the doors or dash, i do believe one is right next to you, and one all the way on the other side of the car. imo, they sound way better, i had my kenwood splits with the tweeters in the doors in my old vl, it sounded shit, with those same kenwood splits in my vt, tweeters in the pillar, sounds wayyy better
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    In the top of the dash/kick panels, they are at a much more of an equal distance than on the doors or B-pillar
    Example... I just measured in my VT from drivers seat to...
    B-pillar right tweeter - 20cm
    B-pillar left tweeter - 110cm
    Difference - 90cm
    Top of dash right tweeter - 100
    Top of dash left tweeter - 130
    Difference - 30cm
    That makes a massive difference to how it sounds.
  1. pic required for vq bcm positioning
    By Zuicider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-11-2008, 11:59 PM
  2. Positioning Splits? VT
    By Semtex in forum Car Audio
    Last Post: 25-11-2007, 03:24 PM
  3. Positioning splits
    By shooter18 in forum Car Audio
    Last Post: 14-11-2007, 09:59 AM
  4. 6x9 positioning
    By G4orce in forum Car Audio
    Last Post: 08-10-2005, 05:46 PM
  5. No. PLATE positioning, UTE
    By blu 5L ute in forum General
    Last Post: 26-08-2005, 06:47 PM
