Page 1 of 4 1234 LastLast
Results 1 to 25 of 81
Thread: Sound 'deadener'
    VZ Acclaim
    Jan 2009
    Default Sound 'deadener'
    I bought some sound deadening sheets a while back with the intent of placing them behind the front split woofers. Having taken the door trim off it seems like a hell of a lot of stuffing around to install it.
    What are your oppinions on the value of sound deadening material, and is it worth the trouble of installing it?
    Cheers again, Dave
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    too right it is buddy. half of my doors weight would probably be sound deadening - i bought some of that sound deadening stuff from holden - $30 a sheet. I used roughly 1.5 sheets on each door. When you knock on them you can really feel the difference, and comparing the sound to my friends stock ute there's marginal improvement in your mid range frequencies.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    LightningVP is offline Donating Member
    None
    Sep 2008
    It is worth it...Well worth it, but you need to get in the mood for doing it ^_^ lol you can't just do a half job with it...
    Mar 2008
    Quote Originally Posted by LightningVP View Post
    Thats exactly right. Generally the people who don't notice any difference between quality before and after have done it wrong/half arsed
    trentvy's Avatar
    trentvy is offline Dodges raindrops
    Vy S pack
    May 2008
    Kilsyth South
    Quote Originally Posted by one_and_only2004 View Post
    you got it from holden? is it like dynamat?
    Juztin's Avatar
    Juztin is offline Bigmacs everywhere
    VT II 99', S Pack.
    Sep 2008
    I'm getting my mate to do my system he is in the area of doing audio etc and sound deadener is one of the top priority's on my list =P
    VZ Acclaim
    Jan 2009
    I currently have 2 sheets of 10"x12", will this be enough for the two front doors or should I look at getting more?
    vs calais eco
    Sep 2006
    Disney land!
    To true! The best way i found to get in the mood for such an occasion is a few however you can also attempt it the good ol fashioned way without a beer....:...........
    Mar 2008
    Quote Originally Posted by trentvy View Post
    It's sound deadener, not exactly as shiny as dynamat or anything but it does the job. It doesnt have adhesive on it but a small tub of selley's kwik grip did my doors - you've got two more than i do though.
    GM Part No M40384 if anyone's interested.
    Comes in massive sheets a bit bigger than those bits of coloured cardboard you get from newsagents to do school projects on.
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Can't say I thought it was worth it when I did my VT.
    The money and effort involved aside, it made bugger-all difference to how much road noise got in (I used 2 sheets per door, and yes tapping on the door it sounded much more "solid", but on-road was pretty weak). In terms of how it made the speakers sound, I can't say I noticed much.
    Given that the sound deadening the VZ comes with from the factory, I wouldn't bother personally.
    VZ Executive
    Nov 2008
    it does make a huge difference but only if done right. sound deadener is not designed to stop road noise, it is designed to reduce resonating panels.
    in my VZ i used 2 sheets of Dynamat from a bulk pack per door, plus I sealed all the service holes with 6mm MDF. well worth it
    trentvy's Avatar
    Vy S pack
    May 2008
    Kilsyth South
    would it help with boot rattle cause thats what I mainly wanna loose. my boot goes nuts on some songs.
    Mar 2008
    You could give it a go i guess - its only going to cost you $40 all up and maybe 2 hours max.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Rattles are two things hitting each other... Put something between them and the rattle will be gone. Foam, rubber, whatever...
    A 2LOUD2OLD said, the sheets of deadener are to stop resonation of panels.
  15. #15
    pugga's Avatar
    pugga is offline More Power!!!!
    05 HSV Maloo R8
    Jun 2005
    Baxter
    Best thing i did. You wouldn't even know there was one sub let only four subs in the boot unless you were in the car.
    If you are going to do it, make sure you do it right the first time.
    Attached Thumbnails Attached Thumbnails Sound 'deadener'-dyna1.jpg   Sound 'deadener'-dyna.jpg
  16. #16
    trentvy's Avatar
    Vy S pack
    May 2008
    Kilsyth South
  17. #17
    eurekamad94's Avatar
    eurekamad94 is offline street kiddo
    kitted, tuned, sick pantha VS
    Jan 2008
    qld
  18. #18
    bpottz's Avatar
    bpottz is offline Whipped By SAPOL
    VT Berlina
    Aug 2008
    South Oz
    Quote Originally Posted by pugga View Post
    umm... wow?
    My VT Berlina [LIONLW] - Lowered, 18's, Leather
    http://forums.justcommodores.com.au/...tml#post863216
  19. #19
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yep thats the RIGHT way to sound deaden a boot, would make a huge difference too.
    If youve got rattles, find the things that are rattling (usually door/lock rods etc) and put a peice of rubber in between them.
  20. #20
    trentvy's Avatar
    Vy S pack
    May 2008
    Kilsyth South
  21. #21
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    You can always put the original carpet back over the top, or cover it with whatever you want
  22. #22
    trentvy's Avatar
    Vy S pack
    May 2008
    Kilsyth South
  23. #23
    bpottz's Avatar
    VT Berlina
    Aug 2008
    South Oz
  24. #24
    None
    Sep 2008
    Quote Originally Posted by cxcxcxvcvcvc View Post
  25. #25
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Quote Originally Posted by bpottz View Post
    sorry, so how much does dynamat cost?
    Around the $250-$300 mark for a bulk pack, which is 36 sq.ft.
  1. sound deadener
    By benny mckellar in forum Car Audio
    Last Post: 19-11-2008, 03:24 AM
  2. Bonnet Sound Deadener
    By lazza44 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-06-2008, 04:12 PM
  3. Quick Sound Deadener Question
    By 1991_Vn2nV in forum Car Audio
    Last Post: 20-02-2008, 07:22 AM
  4. Mysterious body deadener theories
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-03-2007, 05:20 PM
  5. sound deadener challenge!
    By garfa in forum Car Audio
    Last Post: 12-11-2005, 05:05 PM
