Results 1 to 7 of 7
Thread: Amp mount position/orientation
    VZ Acclaim
    Jan 2009
    Default Amp mount position/orientation
    Have just hit another obstacle, I was originally planning to mount the amp behind the rear seat (VZ commodore)... A quick check has now confirmed that infact the amp will not fit without obstructing the centre boot access. The amp is a Pioneer gm6300F, would it be ok to mount the unit on the underside of the parcel shelf? I think I read somewhere that certain amps can have problems with heat dispersion if mounted upside-down.
    If this is not appropriate, can somebody suggest a position that would work without impacting too much on boot space.
    Cheers, Dave
    VZ Executive
    Nov 2008
    i have my alpine mono mounted under my parcel shelf, no problems so far and it has been there for about 4 months
    LightningVP is offline Donating Member
    None
    Sep 2008
    Some will say it doesn't matter, some will say it does...There are no moving obstacles and unless the amp it's self moves then you 'shouldn't' have a problem.
    Here is a pic of how Phreddy used to (or maybe still does) have his in his boot...very good idea
    vx s
    Sep 2008
    auckland nz
    thats a great idea but how much room is there if u have 6x9s in the parcel shelf ?
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Quote Originally Posted by holden boy View Post
    Depends how many amps you are mounting (and how big they are obviously). In my VT I had 6x9s in the shelf, a JL 300/4 mounted between them under the shelf and a Jaycar monoblock mounted to the sub enclosure.
    Now I've got the VZ and I'm not using the 6x9s (they weren't even wired up in the VT, disconnected them after a month ) I have both amps mounted under the shelf.
    It's not a recommended mounting position, and they do get hot if it's a hot day and they've been pumping a while, but they both have thermal protection and it's never kicked in. On a cooler day they get warm. For my purposes and setup I'm not worried about them being mounted like this. If I had a bajillawatt system and I used it to demolish old apartment buildings, I might think twice about it.
    SAV_117's Avatar
    SAV_117 is offline Donating Member
    VY Lumina
    Jul 2008
    statesman
    Feb 2009
    yeah parcel shelf should be ok but beware of how large your sub box is so it dosnt hit it lol i made that mistake haha
  1. New position available *****
    By TappetHead in forum Yella Terra
    Last Post: 21-08-2008, 08:16 PM
  2. High mount log manifolds VS front mount extractors
    By PaRaDoX in forum V6 Development And Modification
    Last Post: 04-04-2007, 06:15 PM
  3. Seat Position
    By Stretcher Bearer in forum The Pub
    Last Post: 17-08-2006, 11:29 AM
  4. Car starts in on position
    By Cal.oz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-04-2006, 09:50 PM
  5. Sub Position
    By TigerVX in forum Car Audio
    Last Post: 08-11-2005, 09:45 PM
