Results 1 to 8 of 8
Thread: Vy/Vz Aftermarket Fascia Removal
    VY II 25th Anniversary Edition
    Feb 2009
    Default Vy/Vz Aftermarket Fascia Removal
    Hey guys, great forum, just joined, been roamin the place for ages tho.
    Was just wondering if anyone knew how to remove the aftermarket head unit fascia from a vy/vz. i just bought a new head unit and DNA fascia on sunday for my Vy and installed it all and was pretty happy with it, then i bought a cat 10 today so i could wide up my steering controlls and when i was trying top remove the fascia SNAP. the ****n thing broke. i dont think the guys at ****obahn will replace it, evan though i just wpent 600 bux there. so i am going to have to spend 50 bux on a new one. Question is, does anyone know how to remove these things without snaping it like i did? there has to be some way because i want to install an amp later down the track and i dont want to snap the fascia again. thanks in advance guys.
    Oppy
    trentvy's Avatar
    trentvy is offline Dodges raindrops
    Vy S pack
    May 2008
    Kilsyth South
    not sure if there the same but my facia just sorta jimmys out. bit of a pull and wiggle it around it comes out. not sure if yours is different though.
    Feb 2009
    trentvy's Avatar
    Vy S pack
    May 2008
    Kilsyth South
    Devils_Thunder's Avatar
    Devils_Thunder is offline Riding high...
    6.0L VZ SS Thunder
    Jan 2009
    Wodonga, NE Victoria
    I have a DNA double din kit and the front fascia just unclips. i use a thin offcut of plastic to pry it out, there are 2 clips on the bottom of the left and right sides.
    Also if you know that down the track you are going to put an amp in run the RCA leads (they are cheap enough to get now) out from behind the unit and extend the remote wire to a more accessible place to connect to later on.
    I did this in my VS because it was a pain getting to the head deck every time i wanted to add something.
    Feb 2009
    yer, mine is a single din, and ther isnt really a way u can detatch it at the sides ounce its in, i got tld u can remove the glovebox and get to the back of the headunit, sum1 told me they did ths when they later decided to install an amp. is this correct? or is there an easier way to remove the facia.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    i had the same problem with mine, the issue is it snaps in real tight and the facia is in two pieces, it has one or two small screws and clips together, if i remember, i broke one clip off getting it out once,
    once i got it out, i got a small file and just put a slight edge on the clips that hold it on, its still tight but its much better
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    05 5sp vz sv6 sedan
    Dec 2010
    victoria
    i recently put in a head unit and the fascia for it in my vz and for some reason the head unit sits behind the fascia instead of infront so i cant simply pull it out and change wires around which is what i need to do since it doesnt save radio stations when it turns off i was just wondering if there was anyway to remove the fascia without braking it so i can change the wires, or do i need to invest in a new one and brake the one i hav?
  1. painting fascia help
    By kazalex in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-01-2009, 01:19 PM
  2. VT Dash fascia removal
    By pogmahon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-10-2008, 10:03 PM
  3. Double Din Fascia
    By Vee Tee in forum Car Audio
    Last Post: 16-05-2008, 10:56 PM
  4. Removal / Installation of WHII Statesman Fascia
    By veeque92 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-01-2006, 08:41 PM
  5. changing fascia
    By chirpies in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2005, 11:27 PM
