Results 1 to 8 of 8
Thread: VT S-1 factory stereo upgrade questions.
    VT V6
    Apr 2008
    Coffs Harbour
    Default VT S-1 factory stereo upgrade questions.
    Just wondering how easy it is to swap out a factory series-1 vt tape/radio for a factory cd player from the later vt-vx range? I was also wondering what size the factory speakers are in the doors of the vt's, and wether they have factory locations for speakers in the parcel shelf?
    Cheers.
    SAV_117's Avatar
    SAV_117 is offline Donating Member
    VY Lumina
    Jul 2008
    should be a straight swap mate should be lol 6inchs in the doors and there are sections in the parcel shelf dont htink it has the wiring though
    VT V6
    Apr 2008
    Coffs Harbour
    statesman
    Feb 2009
    VT V6
    Apr 2008
    Coffs Harbour
    Quote Originally Posted by aaron.blake View Post
    na pretty easy just need the wireing diagram
    So it's not a direct plug in replacement then?
    holdenhero is offline Car idiot
    1998 VT
    Jan 2009
    Maroubra
    I couldn't imagine it being very hard, even putting in more complex DVD players and stuff isn't really a hard task for anyone with half a brain and a little bit of time. If you have the wiring diagram all you have to do is match the wires.
    pugga's Avatar
    pugga is offline More Power!!!!
    05 HSV Maloo R8
    Jun 2005
    Baxter
    If you have the stock double din unit i think you would have, Using a coat hanger cut it in half, insert it into the two holes on either side of the head unit and the unit with come out.
    You can buy a loom adapter so no wires need cutting. you also can buy plastic pockets which will fill the extra space after you install a normal head unit.
    Its such an easy job.
    VT V6
    Apr 2008
    Coffs Harbour
    Thanks guys, i appreciate the help. I'm deciding wether or not to just get a new aftermarket head unit or a factory one out of an upper spec vt-vx. If it's no more work to fit an aftermarket one then i'll just do that.
  1. Factory Audio Upgrade
    By Dowling_s in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-07-2008, 01:20 PM
  2. VX factory stereo upgrade problem
    By gsx913 in forum Car Audio
    Last Post: 12-02-2008, 10:23 PM
  3. factory vt stereo
    By xu1au in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2006, 04:00 PM
  4. Factory Upgrade Alarm
    By Darren in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-08-2005, 06:40 PM
  5. Factory Stereo
    By The1985divo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-11-2003, 08:12 PM
