Results 1 to 5 of 5
Thread: Wiring an amp under the seat
    [ASLYVY] is offline DavidP
    2006 VZ Executive
    May 2006
    Hoppers Crossing
    Default Wiring an amp under the seat
    Hey guys,
    just need some info on wiring under the front passenger seat my 2 channel amp for my front splits that are soon to come
    any other suggestions then under the seat before i say any more?? lol
    i know to avoid interference the power cable and RCAz should b on opposite sides of the car?..how would i get either to come to join under the seat (the easiest or most effective way?)
    and also where would i hide the wiring other than the door sills on the way to under the seat?
    thanks
    LightningVP is offline Donating Member
    None
    Sep 2008
    Hey mate, I have put a amp under my sister seat, (only speakers in front, and sub in back) the speaker wires from left of the car run down the left of the car,, same with sub, the right speaker runs along the dash down the passengers side of the console, same with the rca plugs, along the LEFT side of the console, the power wire runs along the RIGHT side of the console then over the bump and to the amp.
    And we have not noticed any interference.
    All wires go under the carpet where needed, then out a hole cut into the carpet.
    2006 VZ Executive
    May 2006
    Hoppers Crossing
    Quote Originally Posted by LightningVP View Post
    so what your saying is you have all your wires running down the middle console but on opposite sides?..what bump are you talking about with the power cable?..
    thanks
    statesman
    Feb 2009
    not hard just run all your cables and fix the ground to the seat mount and run all tha cables under the carpet wont even know its there
    None
    Sep 2008
    Quote Originally Posted by [ASLYVY] View Post
    thanks
    The 'bump' is the rise in the floor for the tail shaft. But yeah, my wires are running down either side of the console "tail shaft rise", it's not a long distance, so you shouldn't get much interference, if any.
    And yeah, as Aaron said, Earth to a bolt on the seat.
  1. VT to VZ electric seat wiring
    By BerlinaBen in forum Electrical Wiring / Questions
    Last Post: 10-04-2009, 06:36 PM
  2. Help please with wiring up drivers seat from Vy Monaro.
    By v8man304 in forum Electrical Wiring / Questions
    Last Post: 29-03-2009, 06:06 PM
  3. rear middle seat belt bottom half way up seat
    By michua in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-09-2008, 08:20 PM
  4. Converting standard fog light wiring to driving light wiring
    By tungsten_vx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-12-2005, 06:30 PM
