Results 1 to 10 of 10
Thread: How do I use this "wiring harness"?
    VTSS
    Dec 2008
    House
    Default How do I use this "wiring harness"?
    I think my other thread I made got a bit off topic and Im making a new thread here just in case no one goes into the VR section...
    So I bought a wiring harness because my new deck wasnt compatible with my current wiring and all I need to know is do I put the wires from my new deck into these spots, do I need to scrape a bit of the colored plastic around the wires to show a bit of the metal?
    And I put the new wires into those holes.
    Hope someone can help!
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    That adaptor is adapting a VR radio plug to "ISO" plugs (the one your holding and another).
    Not many aftermarket head-units use ISO wiring configs so i would personally shop off the ISO plugs and join the wires from your new head-unit to the wires on the adaptor.
    VTSS
    Dec 2008
    House
    oh i see... but i cant stick the wires in there?
    If i cant, how do you "solder" things on?
    dufus is offline Donating Member
    rickshaw
    Jun 2006
    Quote Originally Posted by CrimsonThunder View Post
    Google is your friend for how to solder
    andyos's Avatar
    andyos is offline Ozzie 98 Clubby
    98 VT CLUBSPORT 5.0L
    Jun 2008
    Wodonga Victoria
    If your not good at soldering you can also buy the wire joiners from supercheap simply stick a wire in each end and crimp them to the joiner.
    VTSS
    Dec 2008
    House
    Mike S is offline Car Audio Pro
    Jul 2005
    Just take it back to where you got it from and order the correct adaptor, they are all available. All the popular ones anyway, Pioneer, Sony, Alpine, Kenwood etc.
    Mike
    VTSS
    Dec 2008
    House
    So I just got (hopefully) one last question. Im onto the ground wire now, do I just leave that or do I have to connnect that too? (connect the ground wire from the head unit to the ground wire in the wiring harness)
    And also. One of the wires on the head units says I need to connect it to the ignition but i have accessories, so i dont need to worry about that?
    1998 vt clubsport replica
    Dec 2008
    Perth, NOR
    yes ofcourse you will have too, or just put a ring terminal on it and screw it into some metal
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yes you will need to connect the ignition wire to the accessories wire.
  1. ""need help"" own a stocko 3800 vp and wanting to really give it some horsepower
    By boourns in forum V6 Development And Modification
    Last Post: 19-07-2008, 06:59 PM
  2. Starcorp Impul Wheels 18"x8.5" and 18"x9.5" Adelaide
    By vs_ss_matt in forum Parts And Other Items For Sale
    Last Post: 24-05-2008, 06:43 PM
  3. Is the warning "service engine oil" the same as "check oil" ?
    By morris in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-12-2006, 04:36 PM
  4. Wiring help for VT "S" driviing lights
    By sweetfa in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-05-2005, 05:11 PM
