Results 1 to 16 of 16
Thread: Subs Keep blowing
    COMMY VP 666's Avatar
    COMMY VP 666 is offline COMMY VP V6
    COMMODORE VP
    Dec 2008
    Default Subs Keep blowing
    hey my subs keep stuffing up
    what can cause them to stuff up, the amp is still fairly new, and there new subs?
    VU SS UTE / 5 Litre Volvo /Trusty Swift
    May 2008
    Penrith NSW
    Do you have the filter turn on so your only getting bass..
    Why is it called Alcoholics Anonymous when the first thing you do is stand up and say, 'My name is Ray, and I am an alcoholic'?
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Did you match the specs of the subs to suit your amp?
    Are they wired correctly?
    Post up model numbers of your amp and subs, makes it easier to help with these problems
    COMMODORE VP
    Dec 2008
    there wired correctly, not sure about filter, so if you have the filter off its badd?
    trentvy's Avatar
    trentvy is offline Dodges raindrops
    Vy S pack
    May 2008
    Kilsyth South
    Mike S is offline Car Audio Pro
    Jul 2005
    Most amps will have a low pass filter, but even if your running the subs in full range mode it shouldn't damage them. The most likely cause is either your under powering your speakers or they are wired incorrectly, meaning that the amp amy be seeing too low a resistance.
    We need to know what gear you have then someone can help you set it up.
    Mike
    COMMODORE VP
    Dec 2008
    hey true
    when engine off i have 12.4volts at battery and amp
    when engine on i have 14.1volts at batter and amp i have 14.0 volts
    my amp is a kenwood KAC - 81004D , 1000Watt, class d, mono power
    my sub is a US Audio 15inch sub
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Ok so specs on that amp is
    300W x 1 at 4ohms
    500W x 1 at 2ohms
    Cant find specs on that sub, Whats the impedance ie 2Ohm/4Ohm?
    single or dual voice coils?
    Wrms rating?
    Jul 2005
    Your amp and sub should work fine if the sub is a 4 Ohm or 2 Ohm type and I'm not familiar with the US Audio range so I'm assuming it's not a dual 2 Ohm sub and you have it running at 1 Ohm which is too low for your amp. Take the wires to the sub off the amp and measure the resistance across them with a mulimeter, if you havnt got one im sure one of your mates will, it must read 2 Ohms or higher.
    Mike
    COMMODORE VP
    Dec 2008
    im just going to put my other sub in, another us audio 15inch
    and turn the settings down, but where should my rca's go, line in or line out
    also i have a setting ISF, it can either be off, 15hz or 25hz
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    COMMODORE VP
    Dec 2008
    hey that does help, but for the infrsonic filter switch, what do you think i should have that on, so i dont blow the sub up again
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    I don't think that will make a difference. But the LPF should be around 80, and the gain set accordingly. The cause of your troubles lies elsewhere, You need to post the specs of the sub (usually written on the back of the sub) as its likely they are being overpowered and clipping.
    Jul 2005
    Set your subsonic filter to 15 or 25 htz, it stops the sub trying to produce sounds that the human ear can't hear anyway. A 15" sub should have a good bass extension at low frequencies, set your LPF at 50hz, although it's a personal preference and depends on your own taste.
    You havn't actually told us what goes wrong with your sub ...... what does "stuffing up" mean?.
    Mike
  15. #15
    VY2 Berlina
    Jun 2008
    Castle Hill
    check you've wired it correctly in parallel, and ensure that the sum of your speakers impedence is close to the rms rating of the amp.
    Ie: If your amp says 500rms @ 2ohm load, and your subwoofers are 4 ohms/250Wrms each, wiring them in parallel will mean they each get 250Wrms, which is what the amp will supply perfectly
  16. #16
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Also, what type of enclosure is the subwoofer in?
    A sealed enclosure will have no holes (ports) while a ported one will have a port/s.
    Maybe its a tuning issue (the port/s are tuned above the music the sub plays).
  1. Fan/Air con blowing down
    By Mungrel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2008, 01:59 PM
  2. FS: 2x 12" Pioneer VCCS Subs in Custom Box! Silver Cone Subs!
    By 1991_Vn2nV in forum Parts And Other Items For Sale
    Last Post: 06-01-2008, 08:27 PM
  3. Air box blowing up
    By goodyear in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2007, 09:42 PM
  4. WHy are my lights blowing???
    By Jamie_87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2006, 02:32 AM
  5. vn a/c & fan not blowing air :(
    By STYALR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-05-2006, 10:19 PM
