Results 1 to 15 of 15
Thread: Which type of speakers to buy?
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Default Which type of speakers to buy?
    Hi everyone, again. I am thinking about upgrading my system even more and I would like some ideas. I currently have Polk MMC6500 splits up front, driven by a Cadence ZRS-1502, and two Kicker L7s being driven by two Cadence ZRS-6000Ds. I now have a Cadence ZRS-7504 sitting around doing nothing, so I was thinking either a second set of splits for the front, or a set of Kicker SS series 6.5" or 8" mid-bass speakers. Basically I'm after clarity as well as volume, as long as it still sound beautiful up loud.
    Also I have just purchased a new Optima D34 Yellow Top, but I was what my best option would be in regards to upgrading my alternator. I was thinking of looking for a Police Spec alternator, I believe they put out an extra 30amps. But any other ideas would be welcome, prices hopefully too.
    Ronald Reagan (1986)
    vr statesman 5.0
    Jan 2009
    im lookn at getting an l7 kicker sub mate how does ur too go?maybe upgrade ur splite to either focal or soundstream,very good clarity and sound.
    VX Berlina
    Apr 2007
    Currently only got one going as the other box hasn't been built yet. As for how it goes, only feeding 700wrms into it and at night, headlights in the rear-view and side mirrors turn into rings!!
    VX Berlina
    Apr 2007
    Also the clarity I'm getting from these Polks are very good, I just want more volume while retaining that clarity.
    Another problem I ran into is that my new Optima battery has the terminals on the wrong side of the battery . The positive terminal isn't a problem but the negative won't reach because off that annoying 90 degree bend in the bracket. So I was thinking of getting a sparkie to put on some new battery terminal (possibly stinger) and putting all the factory cabling into them. But has anyone else used any different methods? And how hard are they?
    Also I'm running the factory ground cables as well as some 0gauge running to the strut tower. Would this be sufficient for about 2000wrms? I'll post some photos.
    VX Berlina
    Apr 2007
    Here are the photos.
    Attached Thumbnails Attached Thumbnails Which type of speakers to buy?-snc00006.jpg   Which type of speakers to buy?-snc00007.jpg
    VH SL/X Wagon
    Feb 2009
    I wouldn't worry about getting an auto elec to put terminals on, it's a piece of piss. Take old ones off, put new ones on, too easy.
    Also, I've got 2 aerpro 0 gauge terminals and they're a bit of alright. Work really well, haven't had any issues yet.
    It was one of these. The only issue I had was the positive battery post was too thick for it, but it was made of fairly soft metal so I just shaved it down with a flat headed screw driver till the terminal went on. Probably not what the experts would do, but bugger it, if it can manage with a smaller negative post I'm sure shaving 2mm off the positive posts diametre isn't going to hurt.
    VX Berlina
    Apr 2007
    I know its not to hard but I haven't got any tools big or strong enough to release the crimps they have on the cabling.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    How much power are the polk splits getting at the moment?
    150db in a commodore =
    VX Berlina
    Apr 2007
    At about 150wrms they start to distort. At least I think its about 150 cause the amp I used was puttin out 300wrms and the gains were set by WOW. They are rated to 125wrms.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Hmmm, ok then sounds to me like your getting the most out of your splits.
    Maybe look into making up a set of fibreglass pods for the front doors and buying another pair of Polk splits?
    Ive looked into mounting a pair in the kicks by remounting the ECU etc, lets just say its more trouble than its worth and youre better off making a set of pods to suit 2 x 6.5s on either side.
    VX Berlina
    Apr 2007
    Yeah I was definately looking into that, but have been quoted around about $500-$550, for fibreglass with whatever covering I want. Thats a lot of money. If I can make the frame then my dad might be able to fibreglass it for me but I don't know.
    Also all of today I was thinking how good it would sound with twin sets of Polks up front, with 8" Kicker mid-bass speakers in the rear doors and the 2 L7s in the boot !!
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Sounds like a plan to me....just buy a set of pods from a wreckers and have a go. It isnt that hard to fibreglass, just take your time and check out some of the "show off your rides and install" section on mobileelectronicsaustralia.com.au......heres a link, you should be able to find some helpful info there on fibreglassing pods etc.
    Board Message
    VX Berlina
    Apr 2007
    The only problem I can see is that for my plan to work I need to run two sets of Polks off my 2-channel amp. The amp is a ZRS-1502 (150wrms X 2 at 4 ohm, 300wrms X 2 at 2 ohm, and 600wrms at 4 ohm), I asked the dude at WOW if I can run both sets of Polks of this amp as this will give me 300wrms per channel at 2 ohm, but he said something about the speaker seeing 2 ohm and they might not work properly as they are 4 ohm rated. Whats all this??
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    No, the splits will work fine at 2 ohm...ive done exactly this several times without a drama. The only real change will be within the amplifier itself, it'll run a little hotter and draw abit more current....but thats about it
  15. #15
    VX Berlina
    Apr 2007
    Excellant!! Holdenboy your a hero and you sub-box looks like it would cause earthquakes. If that port of yours was any bigger then you could climb into it. The other use for your port is an industrial size fan.
  1. Replies: 2
    Last Post: 04-09-2008, 08:18 PM
  2. Replies: 18
    Last Post: 06-01-2008, 07:09 PM
  3. alpine type-x speakers. opinions?
    By sim_vs in forum Car Audio
    Last Post: 31-08-2006, 11:54 AM
  4. FS: QUALITY SPEAKERS (Alpine Type Rs, MB Quart - 6.5') -PICS
    By Raging Bull in forum Parts And Other Items For Sale
    Last Post: 10-05-2006, 02:10 AM
  5. What Type Of Speakers Are In The Vr Berlina
    By Gold_VR_Berlina in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2004, 06:23 AM
