Results 1 to 15 of 15
Thread: Speaker Cut Out When Loud
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Default Speaker Cut Out When Loud
    sorry to keep bothering everyone with so many questions but i just hooked up an amp to my car this afternoon, it is only running rear speakers in the boot nothing else, and when i turn it up loud (JVC 25-30) the speakers that were in the car when i bought it intermittently cut out, the front are stock i think the rear are 220w max pioneer 6inch. any idea why? could it be too much bass or too much power for them?
    Thanks.
    VR Executive S1
    Mar 2009
    It could be to much power to the front stocks, there only about 45 watts, so i'd get new front ones, cause stocks can't handle the amp and short out causing everything else to short out.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by CommodoreMan View Post
    He's not running the front speakers.... and stocks speakers are no where near 45watts rms.
    I check your wiring, its also common for the speaker terminals to earth out on the parcel shelf, and adjust gain setting on the amp, do they crackle or just cut out?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Could be many things...including what vn6pwr suggested.
    I would also check the power/earth connections, making sure their secure.
    Is it just the amped speakers or is it all speakers?
    150db in a commodore =
    VN Commodore
    Jan 2009
    You could try hooking the speakers up to the main deck by them self and see if it does it then. If it does then it must be the speakers but if it doesn't either the amp isn't working properly or the speakers are overloading the amp.
    | evaN |'s Avatar
    | evaN | is offline mmm bass
    VT
    May 2006
    SE Melbourne
    did u tape up the original wires that were going to the rear speakers? my guess would be that they're shorting out when it's turned up and the headunit's cracking the shits.
    Dec 2008
    thanks for the help guys, just running off the headunit. i checked the connections and all good on the hu side of things, so mite check everything in the door and i'm installing some 6.5inch components in the front too, so maybe this will fix things.
    Cheers guys.
    vr equipe
    Jan 2008
    sounds to me like somethings shorting out was happening to me wen i disconnected 2 of the 4 speakers off my 4 channel it would let it go but once the volume got to about 30 it would cut out
    VE 6.0
    Mar 2009
    either the unit is shutting down due to an impedance mismatch or a short. Watch out you down blow your amp.
    Dec 2008
    i've installed my amp properly and tuned with my speakers/sub and i dont need to turn it up so loud that it cuts out now haha. i just have it fading towards the back where my good gear is
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by sweefu View Post
    You should really think about upgrading the fronts, and amping them instead of the rear shelf speakers, since the driver sits in the front, you want the best quality sound in the front
    Dec 2008
    Quote Originally Posted by vn6pwr View Post
    yeah mate i got some new front 6.5inch splits.. they are a british brand called RISEN not sure if anyone has heard of them but they pump ultra hard and sound awesome.. they are supposed to be 95wrms . when i have a spare bit of time i'll take my doors apart and install them.
    Cheers.
    VN V6 Manual
    Mar 2007
    The South
    crvee8 and vn6power are on the money.
    I don't even bother with rear speakers in smaller cars. I will have some in my commodore though for the people in the back. Better quality without them.
    1989 VN 5 Speed – Turbo conversion
    1997 BMW E39 M52B25 Powered.
    1994 Yamaha XT225 Modified
    Dec 2008
    thanks. mate. i've sinced put in some 6.5inch components in the doors and re wired them, so no cutting out now. i am looking to buy another amp to power them in the next few weeks.
    Cheers.
  15. #15
    VN V6 Manual
    Mar 2007
    The South
    I Picked up a 2x100wrms Lanzar OptiDrive second hand at cash converters for $50! These are excellent SQ amps and weighs nearly as much as my 1100wrms monoblock lol
  1. Loud pod
    By -Michael- in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-02-2009, 03:20 AM
  2. Really loud hum from Sub
    By kicker12 in forum Car Audio
    Last Post: 08-09-2008, 11:58 PM
  3. vx ss LOUD
    By aygee in forum LSx Development and Modification
    Last Post: 07-01-2008, 05:11 PM
  4. WTD - VS etc Speaker Door Pod Speaker Grills
    By lil_oneblue in forum Swap / Wanted to Buy / Trade
    Last Post: 08-01-2007, 08:38 PM
