Results 1 to 5 of 5
Thread: Amp Trigger
    VX Berlina & VR Exeutive
    May 2005
    Default Amp Trigger
    Any suggestions, as to what I can do for a Amp Trigger on a VX1 Berlina standard Eurovox.
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Heh-heh....
    Throw the Eurovox in the bin and fit something else!
    (sorry Mate, just kidding)
    I really don't think there's anything you can do without some modification of the head unit.
    (I have a VZ, and the Blaupunkt has no remote or low level output either - I'm in the process of modding that unit to drive/switch my power amp)
    The only thing I might suggest is a switch on the dash or console somewhere that's wired from the accessories circuit through to the amp's remote terminal.
    (that way, even if the switch is left on, the amp will power down once the key is turned off)
    Cheerz!
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    May 2005
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    Just bear in mind that using an accessories as a trigger leaves the amps running constantly even when stereo is off. I suggest using a toggle switch wired in through a relay taking power form the accessories.
    Phreddy's Avatar
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Ummm - good point Trunk. That's kinda along the lines of what I said!
    The relay is a good idea though, as my suggestion didn't take into account when the stereo is turned off.
    (in my car that's never the case!!
    Cheerz!
  1. Factory Alarm trigger
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-09-2007, 02:06 PM
  2. Trigger Happy, or justified ?
    By Trei in forum The Pub
    Last Post: 22-02-2007, 08:51 PM
  3. VT Cooling Fan Trigger Switch - Help?
    By knowledge_is_power in forum Electrical Wiring / Questions
    Last Post: 03-02-2007, 08:22 PM
  4. Help with Write-Off Trigger!
    By Fekason in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-06-2006, 10:09 PM
  5. Amp Trigger ?
    By Fletch_QLD in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-08-2005, 07:33 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
