Pretty sure its a massive cause towards my engine whine (if im correct the Antenna is a ground) anyway i need to know how to get to it, is it as easy as taking the wheel off and taking off the interior surround inside the wheel arch, or does the whole panel have to go?
No, thats about it....remove the wheel and then the "inner guard" and look up into the cavity and you'll see the antenna.
150db in a commodore =
Access to the aerial is gained by removing the inner plastic liner. There is no need to remove the guard.
Sweet, thanks lads!
