Results 1 to 6 of 6
Thread: Vy Amp install
    03 VY Berlina S1
    Jan 2007
    Default Vy Amp install
    Hi all,
    I have a quick question I have a four channel amp and just need to know how to install the RCA converters as I want to run the fronts and a sub off the amp
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Ahh you'll have to explain what you mean by RCA converters?
    Is it the thing that turns speaker cables into RCA cables (line out converter)
    Or RCA splitters which turn 2 plugs into 4 plugs?
    150db in a commodore =
    03 VY Berlina S1
    Jan 2007
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Alrighty you need to connect the inputs of the LOC to the front speaker outputs of the head-unit, easily accessed just above the kick panels before they go into the door.
    Mount the LOC at the back or wherever your mounting the amp, and buy a set of short (50cm) RCAs to go from the LOC to the amp.
    Im assuming youve got 2 LOCs? if so then you'll need to "tap" into the rear speaker wiring in the pillar before it goes into the rear door, dont just cut the wiring though, as your rear speakers wont work then, strip back the insulation and solder/tape new speaker wires, then run those to the LOC and from the LOC to the amp via 50cm RCAs like the fronts.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Oh yeah with the fronts just cut the speaker cabling, attach the cables coming from the head-unit to the LOC wiring and attach the cables that go to the speaker to your amplifier outputs....if that makes sense
    03 VY Berlina S1
    Jan 2007
    thanxs mate that makes sense i am not using a loc box i am using this Schneider line out convertors same thing but and then i get the remote from the back of the deck also
  1. Cai install?
    By Razor- in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2008, 09:06 PM
  2. Install new HU in vx - how to
    By commsirac in forum Car Audio
    Last Post: 27-12-2007, 09:44 PM
  3. can't install XP onto OS
    By bangers in forum The Pub
    Last Post: 05-03-2007, 10:39 AM
  4. VP new install
    By VP_belina in forum Car Audio
    Last Post: 27-03-2006, 11:32 AM
  5. My DVD/LCD Install (what u think)
    By millencolin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-09-2005, 05:05 PM
