OK so here it goes, i have a alpine 9884e and have had it for a while, not bad......
well i took it out of my old car, put it in the new one and it was fine, but now it only works about 30% of the time and the rest it a little light flashes (circles in the pic below)...
Sometimes i will be driving and it will randomly start working and will be fine but once i turn the car off, same thing!
So i thought it may have been a shitty earth, so i took it apart and checked and the earth was actually in a pretty good place but i changed it anyway
STILL HAPPENS!
I was thinking the fuse at the back of the headunit but would it wouldnt work randomly if that was blown.....
I tried resetting it (little pinhole behind the face) and still does it....
SO can anyone help me? it was fine for a week or 2 but now its stuffing up?
Could be many things, maybe a loose connection on either your constant power or accessories connection, even a loose terminal inside the stereo plug itself can cause this.
Pull the head-unit out and turn the key to accessories, then have a play / move around the stereo wiring to test for a loose connection.
150db in a commodore =
yeah thats what i thought it might have been but all my connections were soldered and believe me there is no way of them bastards coming apartlol
its definitely a head scratcher thats for sure...... (unless anyone else has an idea?)
What about the pins inside the Alpine plug that goes into the head-unit?
Its very possible for those to work loose over time, and certainly when transferring the unit into another car.
its possible i guess, ill wait for a bunch of suggestions here and when its daylight ill give it a look, thanks holdenboy![]()
