Page 1 of 3 123 LastLast
Results 1 to 25 of 63
Thread: My S-Pack system
    HamaTime™'s Avatar
    HamaTime™ is online now VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Default My S-Pack system
    ok well I have bought my headunit, I got the Alpine iDA-X200 (direct ipod control unit)
    Now I am ready to start installing some stuff
    What i have to work with now is the headunit and these speakers:
    • JL Audio front 6" splits
    • 6" Rockford Fosgate rears (on parcel shelf)
    • 2 Tweeters on the dash
    Now my mate has a MTX RoadThunder RT404 amp
    and a MTX 12" sub 200 Watts RMS and 400 max (no box) brand new that he never got around to putting in his accord and offered both of them to me for $150, i could get a box for like $30 or make one myself
    Now, I don't know anything about amps or subs, so apparently the speakers in the car (6"JL Audio and Rockford Fosgate's) are like really good, and the guy who had the car before me had a Audio Mobile Acoustic 150WX4 amplifier which runs the six speakers in the car as well as a Rockford Fosgate bd1500.1 amplifier which ran the two 15" subwoofers.
    I only want a single 12" sub, though I don't know which one I'm going to get yet, unless the MTX sub so I want to know these things.
    Will one amp be enough? Can I run the 2 front 6" splits and the two tweeters off the headunit? and can I run the single 12" MTX sub (200 watts RMS 400 Max) and the rear 2 splits off the MTX 404?
    or..
    is the MTX gear not enough?
    suggestions on amps? how many amps? and different 12" subs
    I don't want to rush into this, I want to get some good gear that I don't have to replace, and I want to get a nice good sounding system, that works for all types of music from Metal to Electro/Trance aka doof doof
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Alrighty, to start off with the tweeters in the dash, are they part of the JL Audio splits or are they another set of tweeters? (so 4 tweeters in the front).
    The amplifier situation - you wanna do it the opposite way to how youve described, run the front splits off the amp and bridge the rear channels of the amp to power the sub.
    In my opinion 75wrms is just enough to power the front splits, but the 150wrms to power the sub probably isnt going to be enough. I would purchase another dedicated amplifier to power the sub, something with about 250-350wrms would be ideal.
    The MTX sub sounds fine, just build/buy a sealed enclosure for it (about 1-1.5 cubic foot) and it'll sound good with all types of music.
    As far as suggestions go :
    * Buy a more powerful 4 channel amplifier, something with 100-150wrms per channel. That way you can run the front splits off the front channels and bridge the rears to run the sub.
    * Use the MTX amp to run the fronts (bridged), or fronts and rears, then purchase a second amp run the subwoofer (the Jaycar 2 x 150 / 1 x 500) would be ideal.
    150db in a commodore =
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    The tweeters are seperate, so I have the 2 6" JL's in the doors, 2 6" Rockford Fosgate's in the rear on the parcel shelf, and 2 tweeters on the top of the dash in their usual factory spot.
    So I should get the MTX sub?
    and get 2 seperate amps, 1 to power the speakers, and 1 to run the sub, the headunit obviously doesn't run anything then? will this make it a better system or is it just more power efficient, or powerful?
    also explain the process of 'bridging' and any specific suggestions of amp's? just for reference
    1997 VS II - S
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yeah the tweeters in the dash are apart of the JL Audio speakers (thats why they call them "splits").
    The MTX sub should be fine.
    Yeah the h/u can either run the rear speakers or you can power the rear speakers off the MTX amp. I would personally run the rears off the h/u and "bridge" (i'll get to that) the MTX amp to run the front speakers. The reason for this is because you rarely sit in the rear and you want most of the sound to come from the front speakers (where you are).
    "Bridging" just means to connect two channels of an amp into one channel, which usually doubles the power going to the speaker/sub. This basically means you speakers will be able to play louder without distorting, theres more to it than that but its all you need to know right now.
    The Jaycar amp i suggested to power your subwoofer is this one:
    Precision Response Car Amp 2x150WRMS - Jaycar Electronics
    Its got more than enough power to run your sub (500wrms), and its good value. I can suggest a hell of alot more amps, but just have a search through sites like Ryda (RYDA.com.au - Great Prices on Car Audio, Mobile Phones and GPS Navigation) and have a look for 2ch amps that produce 250-400wrms x 1 (in bridged mode).
    SPLcamry is offline 1000rwhp
    2002 VX
    Jan 2009
    dayboro
    well for a amp i would go with a Digital Desgin M3 amp, this produces 2400rms @ 1ohm and as for a sub i would go a Digital Desgin 9515. If you get this you will be very happpy. This will blast what the people above me posted. You will get into the high 140's if you build the right box.
    But however you would need a DEEP CYCLE battery mounted in the back aswell as one under the bonnet, this is to insure that the volts don't drop under 12v. All up this would cost around $4400 but this will outlast any other sub and amp in the market, Plus it's better then rockford fosgate and MTX.
    VS Acclaim
    Jun 2006
    Quote Originally Posted by SPLcamry View Post
    lol - the guy is looking at $200 gear and your throwing out $4k pricetags. Hamaman whats your budget bud?
    id be looking at a 4 chan amp and single sub setup as suggested originally by Holden boy.
    "The crisis of today is the joke of tomorrow" HG Wells
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    lol, i'll agree you cant compare a MTX amp, MTX sub and a Jaycar amp to DD 95 series sub and a M3........But for 1 eighth of the price it will sound good and last many years if installed properly and not thrashed.
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    Quote Originally Posted by Joe Peeps View Post
    Yeah $4k is really not a good idea...
    my budget is around $200 - $300...my mate has a 800 watt single channel Pioneer amp that he said would be sweet to run the sub, and I was thinking I could get the MTX 12" sub and RT404 amp to run the speakers...for $150...so yeah...what do you guys think?
    1997 VS II - S
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    That MTX RT404 only puts out 37.5WRMS at 4ohm so unless the JL and Rockford splits are rated at 2ohm then they aren't really getting that much power at all.
    As for the Pioneer mono, if it is a GM-7300M then they are a good amp, I had one powering a set of Pioneer TS-W307D2s and it was great. But if you try and hook that amp up to that MTX sub, then unless you get it properly tuned, then you will overpower the sub and kill it.
    Have a look around both shops and Ebay:
    MTX Audio Thunder3404 400W Amplifier - Preowned - eBay Amplifiers, Audio, Video, Car Parts, Accessories, Cars, Bikes, Boats. (end time 23-Mar-09 13:11:52 AEDST)
    Sony Xplod 4/3 Channel Power Amplifier XM-SD14X - eBay Amplifiers, Audio, Video, Car Parts, Accessories, Cars, Bikes, Boats. (end time 23-Mar-09 20:16:53 AEDST)
    New SOUNDSTREAM XTA480.4 480watts 4 Channel Amplifier - eBay Amplifiers, Audio, Video, Car Parts, Accessories, Cars, Bikes, Boats. (end time 23-Mar-09 21:30:00 AEDST)
    This one looks like a great buy
    CADENCE HIGH POWER 4 CHANNEL AUDIO AMPLIFIER - eBay Amplifiers, Audio, Video, Car Parts, Accessories, Cars, Bikes, Boats. (end time 24-Mar-09 17:49:38 AEDST)
    Ronald Reagan (1986)
    VX Berlina
    Apr 2007
    On second thoughts that Pioneer amp might be perfect, if the MTX sub is a 4ohm single coil or a 2ohm dual coil then the Pioneer amp would only put out 200WRMS. So the sub would be running at its max potential and you always have the option of putting a second sub in later and doubling the bass.
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    ok so the Pioneer Amp could be good, and I need a 4chan amp to run the speakers...the Cadence one you suggest would be the best?
    1997 VS II - S
    VX Berlina
    Apr 2007
    I personally like Cadence, but hey I'm a bit biased, I have 4 of there ZRS range in my car.
    Soundstream make some quality products as well. The Cadence amp is more powerful but the Soundstream amp is brand new. Up to you. But there are other places to buy from, try your local store and see how much you can talk them down. A stores warranty is much better than a Ebay promise.
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    Fair enough. Just to clarify, what sort of power/specifications in general should I look at for running the speakers? 4 chan?
    what about this to run the sub? http://cgi.ebay.com.au/KENWOOD-AMP_W...ayphotohosting
    1997 VS II - S
    2002 VX
    Jan 2009
    dayboro
    WHAT no 4k system. But that system should be alright but maybe just save up abit and get something abit more powerfull cause a sedan is crap for bass. I would save up till you have $600. Then get a $400 amp and a $200 sub and it will sound a hole heap louder and better.
  15. #15
    VX Berlina
    Apr 2007
    Yeah that amp will give you 300wrms at 4ohm, so good enough for the 1 sub.
    I still think that the GM-7300M would be the better amp, but your money so its up to you.
  16. #16
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
  17. #17
    VX Berlina
    Apr 2007
    The Pioneer is (in my personal opinion) going to totally out-do that Kenwood. More power, can run at 2 or 4 ohms, class D efficiency, it looks cooler.
    As for the speaker amp, hmmm, maybe not Blaupunkt. Try something like this:
    //////Alpine amp MRP-F250 4/3/2 channel in box rrp$299 - eBay Amplifiers, Audio, Video, Car Parts, Accessories, Cars, Bikes, Boats. (end time 29-Mar-09 19:15:00 AEDST)
    I had one of these, great amp.
  18. #18
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    Is that alpine amp powerful enough? because it looks like it has the same power output specs as the MTX roadthunder RT404...
    1997 VS II - S
  19. #19
    VX Berlina
    Apr 2007
    Hmmm your right. I forgot the amp was only 40WRMS per channel, I kept thinking it was 50WRMS.
  20. #20
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    so still not recommended? it puts out 45wrms...the sub is an RT12, I'd run the fronts and sub off it, run the two rears off the h/u, 90watts each (bridged)
    or...
    http://cgi.ebay.com.au/ws/eBayISAPI....m=170314108643
    (don't know what model that is) I could run that to the sub and power the two front splits, run the rears off the h/u...
    anyone?
    1997 VS II - S
  21. #21
    VX Berlina
    Apr 2007
    I don't know about that amp, no models number or specs
    Try Cadence Q4000 Amplifier - 4 Ch @ 60 RMS; 2 Ch @ 200 RMS - eBay Amplifiers, Audio, Video, Car Parts, Accessories, Cars, Bikes, Boats. (end time 30-Mar-09 20:40:35 AEDST) would work. Or Alpine V-POWER Car Amp MRP-F450 4 Channel - eBay Amplifiers, Audio, Video, Car Parts, Accessories, Cars, Bikes, Boats. (end time 28-Mar-09 19:34:41 AEDST) would be good.
    Have you tried actually walking into a store and telling them your needs. If you get the right sales attendant, good discount can apply.
  22. #22
    VK
    Jul 2004
    this is a deadset bargain:
    Eclipse XA1000
    Go for a dual voice coil 4+4 ohm sub with it and it'll have plenty of power on tap for the average listener.
  23. #23
    VX Berlina
    Apr 2007
    That amp is no good because you can't run splits off them.
  24. #24
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    yeah I've been into JB Hi-Fi, all they were intrested in was trying to sell me a $700 Kicker amp with only 4 channels...I was like 'mate i can get a Precision Response amp from Jaycar, 5 channel, 700 watt for $450' I want a cheaper option that will do the job...
    Ok so I'll try and go for the Cadence and the Alpine...
    Run the sub and front splits off them...then run rears off h/u
    1997 VS II - S
  25. #25
    VX Berlina
    Apr 2007
    Yeah some stores or salespeople are like that, unfortunately.
    Its such a waste running the Rockfords off the H/U since they are good speakers. But nothing says you can't add a mono amp later and put the Rockfords onto the 4-channel.
  1. Help!! VT S Pack
    By vt_chick in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-09-2009, 08:59 AM
  2. vs series 2 coil pack?? any coil pack will do????
    By steak000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2008, 07:52 PM
  3. Exhaust System for my vy s pack supercharged
    By pugs2008 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-09-2008, 06:57 PM
  4. my 78 sle 310 pack
    By ajcsle78 in forum VB - VC - VH - VK
    Last Post: 01-09-2005, 08:23 PM
  5. Replacing Series I Coil Pack with Series II Coil Pack.
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2005, 10:04 AM
