Results 1 to 15 of 15
Thread: what is the problem with my system?
    VZ SV6
    Aug 2006
    Default what is the problem with my system?
    hello all..
    my system composed of JVC 2-Din HU connected to a Kenwood 640w max destrbuting to four 6.5" 180w max JBL door speakers.
    the problem is the 4 speakers act like every two speakers act like one ( right & left)
    for example when i change the sound to the right and left from the HU it do ok .. but when i want to change front and back it act like the rear speakers is connected with the front .. just when i make the sound from the front only the sound still come from all 4 speakers and when i change it to the back only all speaker go silent ?
    this is my system components :
    http://www.jvc-me.com/productAccesso...uctid=KW-XG706
    Kenwood - KAC-8401
    JBL Car & Marine Audio
    help please
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Firstly mate i'd like to thank you for supplying us with the links/pics of the products you have installed, makes our job easier
    I just have one question for you........do you have the user manual that came with the head-unit?
    I ask this becasue the specs from the link you gave only say the unit has 2 pairs of RCA preouts, but below this states it has subwoofer control. What i would like to know is this second preout switchable from rear to sub?)
    What i would assume has happened is the installer (or yourself) have used one RCA cable to connect to the head-unit (out of the front preouts) and then used a pair of RCA splitters to split the two RCA plugs into 4, and connected the 4 plugs into your amp. This means the amplifier is only receiving the front outputs of the head-unit, which would be the reason why you cant fade from front to rear.
    If im confusing you let me know and i'll make it easier to understand
    150db in a commodore =
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Holdenboy I was literally typing the same sort of message when I noticed that you had already beat me to it. Your reply wasn't there when I opened the thread, curse your quickness .
    Ronald Reagan (1986)
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    VZ SV6
    Aug 2006
    thanks for your help ..
    i check the preouts and took this pic from the backside of the HU
    Attached Thumbnails Attached Thumbnails what is the problem with my system?-20090325105.jpg
    VX Berlina
    Apr 2007
    Theres your problem, only the front preout used. Just put another RCA cable from the rear preouts into the channel 3+4 inputs of the amp, assuming the installer was smart enough to put the front speakers on channels 1+2.
    trentvy's Avatar
    trentvy is offline Dodges raindrops
    Vy S pack
    May 2008
    Kilsyth South
    do those rcas look plugged in the wrong way to you? it you were colour coding or not?
    VX Berlina
    Apr 2007
    HAHA, yeah I didn't even notice that. It wouldn't make a difference if its also plugged in the wrong way at the amp.
    Who did this installation anyway?
    trentvy's Avatar
    Vy S pack
    May 2008
    Kilsyth South
    VZ SV6
    Aug 2006
    lol... guys you made me regret installing in that place
    well i took another cable and adjusted the amp .. so i think the problem is solved as the fade works now
    thanks all
    PS: before i post here i asked the monkey and he said at first it can't be done and another one said he will do it for $70 , after i bought the cable for $8 did it myself .. lol
    trentvy's Avatar
    Vy S pack
    May 2008
    Kilsyth South
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    I think its fair to say dont go back to that "monkey" mate, if he cant connect a 4 channel amp properly his installation skills arent flash
    VZ SV6
    Aug 2006
    yah as you said i ran another rca cable .. and sure i won't go there anymore
    thx all
    VN V6 Manual
    Mar 2007
    The South
    They just try to save costs with one rca cable... I had it happen so many times in mates cars who took them to 'reputable' shops. Alberts in WA is one dodgy place. I have seen them triple tek screw down a 2 gauge cable, after two months the hole and lug started getting rusty bits on it... and the body will just rust away at the floor. The same happened for the strut tower that they tek screwed the fuse holder into..
    I bought a 400wrms sub and it got supplied with very thin speaker cable, that I wouldn't even run my 50wrms front speakers to. I asked him if he could upgrade the cable since they would fit the sub to the box and they said yes... I opened it to check and it wasn't. I'll only ever do any car stereo myself now.
    1989 VN 5 Speed – Turbo conversion
    1997 BMW E39 M52B25 Powered.
    1994 Yamaha XT225 Modified
  15. #15
    VZ SV6
    Aug 2006
    me too wona do the work but my knowledge is limited
  1. VE CAN Bus System
    By muzzz89 in forum VE Holden Commodore (2006 - ?)
    Last Post: 26-08-2008, 08:43 PM
  2. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  3. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  4. Problem Flushing the Cooling System
    By VT Dave in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-04-2007, 01:38 PM
  5. Help with new system
    By nath_120 in forum Car Audio
    Last Post: 08-06-2006, 04:26 PM
