Results 1 to 3 of 3
Thread: cat steering wheel
    vu ss 5.7L
    Sep 2008
    Unhappy cat steering wheel
    how do you install the cat steering wheel, what wires to what wires, lol have had it 4 ages just cant work it out any help
    Devils_Thunder's Avatar
    Devils_Thunder is offline Riding high...
    6.0L VZ SS Thunder
    Jan 2009
    Wodonga, NE Victoria
    Cat 10 - Instructions
    This Should Help,
    Red -> Accessories
    Black -> Ground
    Blue -> Antenna Out
    HOLDEN VT/VX ->
    Confirm the vehicle’s Black/White trace is ground (factory). Connect CAT10 Brown to vehicle Brown. For Calais, Statesman, Caprice & Monaro V8, ground the vehicle Black/Yellow trace & connect CAT10
    Depending on what head unit you have and how you are using it (direct or infra-red) will determine where you put the jumpers. (across 1 to 5)
    For your model car you shouldn't need any jumpers from 6 to 10. Ref lower half of page 2.
    See how you go with that, I may be able to help with any other Qn's if you've got any.
    04 VY Commodore acclaim s2
    Aug 2009
    Default help with cat 10 (car audio)
    Hey i am needing help with my cat 10. i have just put in a new kenwood dvd player (dnx7320)commodore, i have installed the cat 10 excactly how it says in the intructions red to acc and black to grnd, the jumper config is 1,3,4 for kenwood direct connect and 7,10 for vy commodore. I have Ground the vehicles Black/Yellow trace and connect CAT10 Brown to vehicle Brown. i have cut the 3.5mm jack off and conected the grey wire only to the kewood direct conect cable. but nothing. Have i missed anything? If anyone can help me it would be much appreciated, cheers
LinkBacks (?)
  1. Boss kits for VT steering wheels to fit a VZ/VY steering wheel?
    By nEb. in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2011, 07:28 PM
  2. Steering wheel mod on VY
    By ay zee in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-09-2008, 07:44 PM
  3. after market steering wheel made steering crap!
    By jet_pilot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2008, 09:07 PM
  4. VZ steering wheel in VP
    By Cootie in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2007, 02:07 AM
  5. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
