Results 1 to 5 of 5
Thread: Problem with Pioneer 4050 HU
    VZ Acclaim
    Jan 2009
    Default Problem with Pioneer 4050 HU
    I am almost finished the wiring on my HU, however I have hit yet another snag. It appeared that the retail adapter that I was using had placed the 'constant battery' pin in the wrong position (it was in the app+), and as a result was not storing anything in memory (radio frequency, bass/treble settings, etc). Since moving it, I do not have any problems with memory, however, I cannot get the thing to turn off... Even on removing key from ignition, closing doors, locking doors, etc, it remains on.
    Is there any way that I can retain memory, however have it 'turn off' on locking the doors or as the stock unit did when the drivers door was opened?
    Any help would be greatly appreciated.
    Cheers, Dave
    Mar 2008
    Do a bit of a search around,I've heard of this before.There is 2 wires on the adapter that have to be swaped.
    Mar 2008
    I copied this from somewhere else.It's for a vy but I think they are the same.Just check it with a test light 1st.
    On the end of the aerpro adapter that plugs into the car, the red and yellow wires need to be swapped.
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    VZ Acclaim
    Jan 2009
    Cheers guys, problem solved
  1. Pioneer amp problem
    By metalfossil in forum Car Audio
    Last Post: 14-12-2008, 06:24 PM
  2. Pioneer CD tuner and electric aerial problem
    By VR mad in forum Car Audio
    Last Post: 20-05-2008, 11:02 PM
  3. Replies: 0
    Last Post: 14-10-2007, 10:14 AM
  4. Problem with Pioneer AVH-P5950DVD!!! Help!
    By 1991_Vn2nV in forum Car Audio
    Last Post: 07-09-2007, 05:36 PM
