Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: where to put the crossover?
    ephect's Avatar
    ephect is online now Donating Member
    VS Acclaim V6
    Jul 2006
    Default where to put the crossover?
    hey crew, i need some suggestions.
    i've installed splits a few months back, but didnt have another amp so i havent had them connected. i've finally amp'ed up run most of the wiring from the boot to the front, to the tweeters, but still need to find n splice into the existing wiring for the woofers or run new ones (fun i know!).
    where have you placed the crossover? i've seen them screwed to the doors but dont want them in view. where can i secure them to out of view. i was contemplating screwing them to the kick panels but on the drivers side the accelerater is in the way.
    suggestions?
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    I have a VP, but i've put my left crossover in the back section of the glovebox, and the right crossover as you said inside the driver's side kick panel. I'm not sure if it would make a difference or not, but i wouldnt have the left crossover in the drivers side, so far from the woofer and tweeter, and keep them equal distance apart, and as close to the speakers as possible..
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    i wouldnt put both crossovers next to each other, rather each crossover in the same location on each side.
    VSII Berlina
    Apr 2007
    rural SA
    In my VS there's a plastic shelf behind the glove box which is where I've got my left hand one. There's also a shelf on the right hand side in the same position if you drop the panel below the steering column, but its a bit more difficult to get to. after doing the left one i cbf with it and just tech screwed it against a metal strip underneath next to the steering column where there was enough room for the plastic cover to close over it.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    thanks crawfy, did u screw it to anything on the left hand side or is that sucker just floating round?
    lol tech screwing it, i'll check it out over the weekend.
    VSII Berlina
    Apr 2007
    rural SA
    yeah i drilled a hole through the shelf and just ran a bolt through one of the mounts on the crossover, it's sitting on a carpet sort of lining and doesn't move at all
    Mar 2009
    Cairns White Rock
    I stuck mine down with double sided tape,saved a lot of time stuffing around with drilling ect, and it hasn't come loose....yet-
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    yet another brilliant idea, i have some industrial double sided stuff too, this shit dont let go
    VK
    Jul 2004
    ive got mine in my boot mounted next to my amps, look too pretty to hide away
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    I managed to fit mine behind the plastic air vent cover on either end of dash and drilled them into the metal that's there. It's a pretty tight squeeze but they are out of the way and easy enough to get to if I have to.
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by bezz View Post
    Are you saying you put your crossovers for your front splits in the boot? I always thought that the crossover's should have been within a certain distance from the speakers.....just a thought though i could be very wrong- I' ve got my crossovers for my rear splits in the boot, i taped them ( yes tape again!!) to the boot hinge rails.. Thier out of the way from everything and you can't see them either unless you really stick your head in their. i'd just use that industrial strength double side tape you got mate, people always laugh when i say yeah i just got em taped in there, but their not going anywhere, it looks neat cause you can't see any screws, and if you ever wanna sell anything in the future, at least your gear will still be in mint condition-
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Crossover distance from the speakers does not matter. Having them so far just means you need 2 long lengths (xover to speakers) & 1 short (from amp to xover) rather than 1 long length (amp to xover) & 2 short lengths (xover to speakers).
    Mar 2009
    Cairns White Rock
    Looks i might be relocating my crossover's front the front into the boot aswell then!!
    VY Berlina V6 / R31 Skyline
    Dec 2008
    hey mate i put mine in my door pods for the front haha just drilled tiny holes for the speaker wire and put them in there, good if they come loose or anything
  15. #15
    Dec 2008
    sorry, by door pods i mean the little bit where you can stick maps and stuff next to the speaker bit of the door pod
  16. #16
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by sweefu View Post
    That would look gay and ruin his trim
  17. #17
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    I put mine in the plastic part that is above your feet..... took them out, screwed them in, wired them up then put the plastic bit back in, no one can see it
    its just a matter of a couple screws from underneath
  18. #18
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    thats for the input guys.
    i havent done anything on this yet, i'll just put em under the plastic bit, nice and close to the splits, not running 2 lots of speaker wires from the boot, i want to keep it simple, and i prefer sound over looks in the interior. the boot is a different story, eventually.
  19. #19
    Chirpstr's Avatar
    Sep 2007
  20. #20
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    lol it'll actually be above the plastic bit, not under. the plastic bit is above where your feet are when sitting in the seat. behind the bottom of the glove box and behind the bottom of the fuse cover on the drivers side. its screwed up using those plastic screw clip screws should be 3-4 on the passengers side, and 5 on the drivers side.
  21. #21
    eXphoid's Avatar
    eXphoid is offline I have no license yet xD.
    VZ executive & VS Equipe S2 Ecotec
    Dec 2008
    VIC
    Agh the beauty of the search tool. just what I was after.
    i'm trying to somehow hide it inside the door but the windows are quite annoying.
    need to put them somewhere else i guess but i hate all the cable work
    My 1997 VS S2 Equipe [First Car]
  22. #22
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Quote Originally Posted by eXphoid View Post
    You can (apparently) hide them on the inside of the door trim itself. You will see on the back of the trim there is a bit of room where the arm rest is (behind the sound proofing crap of course). I've never done it myself but it seems to be the done thing
  23. #23
    VZS-Ute06
    Aug 2006
    Western Vic
    Quote Originally Posted by HoldenCommodoreVP View Post
    ...... I' ve got my crossovers for my rear splits in the boot, i taped them ( yes tape again!!) .....-
    I use Scotch 33 Biseal. A self amalgamating tape instead of soldering
    it fuses to itself and is waterproof it is impossible to come loose ever
    1 roll will last a lifetime of car audio installs
    VZ-Rob
    98 Ron Powerchip: CAI: SuperLows: GTS Swaybars: Tinted: SS Grille: SS Vents: SS 2:25 Twin Exhaust: ASR Audio:
  24. #24
    eXphoid's Avatar
    Dec 2008
    VIC
    Quote Originally Posted by Philthy View Post
    thanks.. i did that today. didn't need to mount it either because the sound proofing was really sticky, stuck right back on tightly gripping the xover - doesn't budge
  25. #25
    Summer-Sickness's Avatar
    Summer-Sickness is offline 2005 VZ EXEC
    05 VZ Executive
    Jan 2007
    Rockingham, Perth
    cable tied mine in the top of the footwells, theres plenty of room up there lol
    REHAB IS FOR QUITTERS!
    MY 2005 VZ EXECUTIVE
  1. Where to put crossover for tweeters in car???
    By Semtex in forum Car Audio
    Last Post: 08-11-2007, 07:02 PM
  2. Crossover question?? + Sub Q
    By MikeVXSS in forum Car Audio
    Last Post: 19-03-2007, 10:27 PM
  3. Crossover Problem
    By vtwgn in forum Car Audio
    Last Post: 19-03-2007, 01:20 PM
  4. damages crossover
    By yobbo88 in forum Car Audio
    Last Post: 12-08-2006, 12:08 AM
  5. crossover wiring. help?
    By jmc04 in forum Car Audio
    Last Post: 23-07-2006, 10:20 PM
