My VS Calais Eurovox 10 CD Stacker has a problem
I recently went to play some CD's and after searching through the stack it ended up Error 99
I think i pressed the buttons too quick and i have jammed 2 cd's
The cartridge wont eject either
If there is 2 cd's stuck, what do i do to fix it
And i dont want anyone just saying "Throw it away as its rubbish" as i have found it OK till now and want to fix it
I feel it was my fault being too quick to change Cd's
Stop looking for the Potholes and sit back and Enjoy the Ride
You can try resetting it by pressing and holding the on/off button for six seconds. If that doesn't work pull the power cable out and reinsert it.
The Error 99 code is a common fault with these Eurovox models. It is usually a sign that you are up for a hefty repair bill or a new stacker.
Well i pulled the unit out
Took the covers off
And found a CD stuck
Pushed it back into the cassette and it all worked again
Good to hear your stacker is working again.....sometimes its just as simple as that![]()
150db in a commodore =
just on the cd stacker problem,
my has decied to not work and
keeps coming up with error disc 4 any hints??
