Results 1 to 11 of 11
Thread: few questions on putting new stereo system in vx
    VX Executive
    Mar 2009
    Default few questions on putting new stereo system in vx
    hi all just new to the site just have a few questions i am planning on puttin a new head unit in my vx its got the stock setup in it at the min my plans are to put a new head unit in i already have the single din pocket and the wiring harness with the plug for the stock head unit i want to replace the speakers in the doors and put a amp and sub in it just want to know the best setup could i run all the speakers off the head unit and just run rca's to an amp for the sub? any help would be great thanks
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Your post is a little confusing, but here goes....You say run all the speakers off the H/U .... and run an RCA from the H/U to the amp for the sub- You will need to run RCA's to the amp either way, it's how it pick's up it's signal from the H/U. So are you saying you will be amplifing the sub only?? If your not going to amplifiy your speakers, i wouldnt bother replacing them, just for an example, dont quote these figures!!your stock speakers would at least be capable of 30 watts RMS , your aftermarket head unit would provide around 12-15 watts RMS per channel, so upgrading your speakers without an amplifier isn't going to show a huge improvemet, lucky to be any...If you are adding an amplifier to the speakers,aswell as an amp for the sub, make your the head unit you buy has more than one Pre out, meaning you can add more than one amplifier to it, If you want more advice list your budget and the type of music you mainly listen to and the features you would like (also whether you will be installing it yourself..)
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    sorry to hijack the thread but since the OP is doing a stereo install, he may need this info as well.
    how do you go about wiring parcel shelf speakers from the rear doors?
    probably been covered before, but i couldnt find the relevant info.
    do you need to actually remove the wiring out of the door (from the speaker) or is there a connection before the door?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Short answer to your question, yes you can run all your speakers off the head-unit and just run an amp to power your sub.
    A good option for you would be to get yourself a 4 ch amplifier. This way you can bridge the rear outputs of the amp to power the sub and run the front speakers off the front outputs of the amp. Then you will maximise the sound quality and volume from the aftermarket speakers youre planning on buying. 4 channel amplifiers arent that much dearer than a 2 channel version, and the benefits you'll get will be well worth the extra cash.
    150db in a commodore =
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    davway.....underneath where the seatbelt goes into the B pillar is the wiring for the rear doors, you'll find the speaker wiring there.
    Nov 2003
    Warrnambool
    Quote Originally Posted by holdenboy View Post
    thanks
    do i have to cut the wire or is there a plug?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Cant remember now....i know thats where they are from tapping into these wires to run line out converters.
    VX Executive
    Mar 2009
    so if i buy a head unit 4 6" speakers a sub and a amp and just run all the speakers to the amp can i run the sub off the amp to and will it sound alright? what sorta amp will i need
    VK
    Jul 2004
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    trentvy's Avatar
    trentvy is offline Dodges raindrops
    Vy S pack
    May 2008
    Kilsyth South
    Quote Originally Posted by todd_harris View Post
    not really, try to think of each channel as a speaker like front left (FL) front right (FR )etc
    a 4 channel amplifier will power 4 speakers. but all channels are being used so no you cant run a sub. thats the easiest way of explaining now as for your options
    OPTION 1
    Get a 4 channel amplifier for your speakers and a monoblock amp for your sub (mono block is specially designed for running subwoofers)
    OPTION 2
    run all your speakers off the head unit and just get a monoblock for your sub (with aftermarket speakers running off an aftermarket head unit you will get slightly clearer sound)
    get a 4 channel amplifier and amp your front 2 speakers (leaving the rears ran off the head unit) and bridging the other 2 channels of the amp to power your subwoofer.
    hope that helps. wow that was a fair long post for me. its HOLDENBOY POST!!!!!!
  1. putting on xforce system?
    By vessm in forum VE Holden Commodore (2006 - ?)
    Last Post: 19-06-2008, 01:21 PM
  2. stereo system
    By holiday2 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-01-2006, 12:03 AM
  3. DVD/stereo system
    By FINCH in forum Car Audio
    Last Post: 12-10-2005, 04:07 PM
  4. Putting Alarm System in VT
    By VTSSDUDE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-07-2004, 09:55 AM
  5. New stereo system questions...
    By vl_boy03 in forum Car Audio
    Last Post: 03-06-2004, 12:33 AM
