HI, is there anyone about(yeah i know its easter and most ppl have a life...but ) that can tell me if it is possible, i know its possible but if it will destroy the sound, to put 2 thin panels of perspex into the sides of a sealed sub box? I have some lights i want to install and would like to have say a 8-10cm strip perspex on sides.(resealed)..will this cause too much flex or should i make a false casing for the lights? its just a 1200w 350w 12" jvc cheapy but may as well make the most of it . cheers
jojo
you would want at least 3/4"-1" policarbonate thin perspex will probably just shatter
Yeah use failry thick perspex, certainly thicker than the wood you are using. Also make sure to seal it well.
150db in a commodore =
I've had good results using policarbinate, never used perspex although I guess it's just a lower grade of material. Obviously the thicker stuff you use the better but it's horrendously expensive in thicker sizes. I used a piece about 500mm long x 250mm wide x 10mm thick in a double sub box and it worked great. I couldn't feel any flex in it at all, no more than you'd feel using 18mm MDF anyway. It sounds like your going to do much smaller areas but I wouldn't go any thinner than 8mm or so.
Have fun with it, it's a very neat thing to do, especially if your going to use a strobe inside the box.
Here's a hint .... paint the inside of the box white and use a black light strobe, the effect is awsome. Also have a play with mirrors, the possibilities are endless.
Mike
