Results 1 to 14 of 14
Thread: i need help badly
    VZ Acclaim
    Nov 2008
    Default i need help badly
    my cousin and i recently put a small sound system into my VZ acclaim which includes a pioneer head unit, amplifier and subwoofer. its been working great unitl recently where the power light on the amp goes on then off in 1.5 sec intervals. i replaced the power wire and the sender wire and that hasnt helped. the fuses on the power wire and amplifier are still good.
    PLEASE HELP!!!!!
    lil_mickey's Avatar
    lil_mickey is offline LOUD AND PROUD
    VH 253 :-)
    Jul 2006
    Geelong; Victoria
    sounds like it might be a dead short to earth.... check all your connections including where the power goes into the amp... also if you can, feel the wires for heat.
    Just my 2 cents worth...
    Quote Originally Posted by wraith View Post
    Your not cool till your car looks like a dog with worms.
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Have you checked the earth wire?Power wire is only one half of it, without a proper ground, you should expect problems as such..Your grounding wire and point, should be your next step on your trouble shooting list.
    lil_mickey's Avatar
    VH 253 :-)
    Jul 2006
    Geelong; Victoria
    Also what type of amp and where did you run your earth?
    redcv6's Avatar
    redcv6 is offline supercharged intercooled
    vy ss ute, diesel landcruiser 100s, hq panel van
    Aug 2006
    Ringwood
    trentvy's Avatar
    trentvy is offline Dodges raindrops
    Vy S pack
    May 2008
    Kilsyth South
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Gremlins or Elvis
    Ronald Reagan (1986)
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    I'll say faulty amp then
    Models numbers of the equipment will help us diagnose.
    social's Avatar
    social is online now Commodore Enthusiast
    2006 6.0L VZ Thunder
    Nov 2008
    South Aus
    Earth to Magee....
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    VZ Acclaim
    Nov 2008
    Quote Originally Posted by lil_mickey View Post
    im using a Pioneer GM-D7400M Class D monoblock and the earth is on the boot hinge
    VL EXEC
    Aug 2008
    perth wa
    pull up boot carpet and take bolt that holds the chair down put said earth on there do bolt up check results
    I've driven fast cars I've done stupid shit in them each time i seem to come out on top i love you guardian angel
    vp ss 3 months to go
    Mar 2009
    Cairns White Rock
    Try earthing it out on the metal behind the rear seats, just pull one of the side top seats out, they just slide up then out if you didnt know. There will be few holes for you to choose from. This is the most common and cleanest earthing point people use in commodores. I'm not too sure about using the boot hinge....That way you will know for sure if it's a problem with the earth. You dont have any loose wire threads around the terminal sticking out or anything do you It only takes one little strand of wire and it can stop everything from working. What gauge wire are you using for the earth, if your not sure, then your earth wire, should be at least the same thickness, as your power wire. Remove the fuse from the amp aswell, while your doing all this...
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Quote Originally Posted by Magee View Post
    It's blown... Take it back to the store to be sent off for repair.
  1. wanted badly
    By lukieboy in forum General
    Last Post: 05-12-2008, 06:47 PM
  2. help i effed up badly
    By Haydz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-12-2007, 06:23 PM
  3. Mechanics behaving badly
    By DannyboyDS in forum The Pub
    Last Post: 17-03-2007, 01:14 PM
  4. i want a VL or VL calais badly
    By DT0588 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-11-2005, 09:22 PM
  5. Please do not think badly of me.....
    By dragrat in forum The Pub
    Last Post: 19-07-2004, 09:28 PM
