Results 1 to 6 of 6
Thread: Installing a Head Unit
    Executive
    Apr 2009
    Question Installing a Head Unit
    Hey guys, new to the forum here.
    I go for my P's in a few weeks and recently have just bought a Commodore 1993 Executive.
    My problem is that the original Head Unit doesn't work anymore. So my sister gave me her old Head Unit and when I went to install it, I found that my Wiring Harness was too small to plug into the port.
    Here's an idea of my wiring harness:
    AP1782H : Holden Commodore / Toyota Lexcen VN-VP Wiring Harness 1988 - 93 :: Harnesses
    I have a couple of questions as a result:
    1. Is there anyway I can use my sister's Head Unit in my car by changing the Harness or would it be easier to just buy a new Head Unit?
    2. If I buy a new Head Unit, how will I know my Wiring Harness will be compatible with it?
    I'm only new to the car world and still trying to get my head around it, full answers I would really appreciate but helpful comments would also be good.
    Thanks guys.
    Trayner's Avatar
    Trayner is online now L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    Quote Originally Posted by Executive 1993 View Post
    Thanks guys.
    Well firstly what brand of headunit is it?
    1, Yes , go down to autobarn and get a new harness they should have plentey of (brand) to commodore
    then its just a matter of wiring it up
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    There seems to be a trend these day's with buying and using wiring harness adapter. Firstly you dont need them, and secondly, if your not sure on what your doing, you'll still get stuck,you'll find a lot adapters will have the Accsesories, and constant power supply around the wrong way, plus others- like power antenna wire... Just follow the VN-VP stereo wiring diagram sticky, in the car audio section. You will seriously have your head unit in and working before the store even figures out which harness you need from their catalouge../
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Unfortunately no matter what brand head unit you buy, the standard plug in your commodore wont be able to be plugged into the head-unit. You have two choices:
    1. You buy a harness adaptor, which basically changes your stock stereo wiring plug into an aftermarket (for example Pioneer, Sony, Alpine, Kenwood) plug. This means you can plug one end of the harness adpator into the stock plug and then plug the other into your aftermarket head unit. But as commodorevp has said above usually the harness adaptors arent 100% correct in matching up which wire does what, so you'll have to swap a wire or two around in the harness adaptor.
    2. Follow the head unit installation guide at the top of the car audio section.
    150db in a commodore =
    VY2 Berlina
    Jun 2008
    Castle Hill
    if you know how to use a multimeter and solder, and have wiring diagrams, do it yourself.
    If you're missing those skills, go for the harness.
    I understand some people wont touch wiring and electrical things, just as i wont touch anything mechanical.
    Executive
    Apr 2009
    Thanks guys. But I think my best bet is to go to Autobarn.
  1. installing head unit in vy
    By lok in forum Car Audio
    Last Post: 03-10-2008, 07:36 PM
  2. installing my head unit
    By bognog in forum Car Audio
    Last Post: 03-09-2006, 04:49 PM
  3. Installing head unit....
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-10-2005, 06:48 PM
  4. Installing head unit
    By Muttley in forum Car Audio
    Last Post: 11-09-2005, 03:21 PM
  5. Installing Head Unit
    By stheggie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-07-2004, 04:30 PM
