Results 1 to 7 of 7
Thread: sub not running
    VY S soon to be SS
    Feb 2009
    NSW
    Default sub not running
    ok, ive got fairly limmited knowlage about this stuff so go easy and feel free to correct me if ive made a mistake.
    so ive just bought and had installed a pioneer h/u (avh-p4050dvd) alpine type R 6" in the front doors, stock speakers in the back doors, a 4 channel 600w pioneer amp and a 800w mono block.
    the h/u only ive got apparently only has front and rear outputs. so ive got the 2 front speakers running off the 4 channel amp, the 2 back speakers running off the h/u and the sub running off the 800w mono block.
    but the sub just wont go, ive checked all the wiring and the amp does turn on but the sub wont run.
    the manual says the rear out put can be used for a sub so thats not the problem.
    ive got no idea what needs to be done, can any one shed some light on this problem ? or does anyone else have this h/u or similar runing a sub?
    cheer,joel
    live fast---drive faster
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Ok so you got the Pioneer amp (guessing its a GM-6300F) bridged into 2-channel to run the Type Rs, right? Good choice, feed those speakers power! And you are using the rear pre-outs to run the sub, right? Have you tried using the front pre-out to test the mono and sub? Give that a whirl. If the amp is powering up then its probably not an electrical issue to the mono, using the word probably there. Also are you 100% sure the sub works? Have you tried running it off the 4-channel, using channels 1 & 2 bridged, since you know that amp is working fine?
    My few suggestions, others will have more.
    -Adrian
    Ronald Reagan (1986)
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    You say you had this gear installed?
    By who, and was the sub working when it was first installed?
    150db in a commodore =
    VY S soon to be SS
    Feb 2009
    NSW
    Quote Originally Posted by acarmody View Post
    -Adrian
    yea mate its a GM-6300F, but i havent bridged the channels yet but im goin to and yep using the rear pre-outs to run the sub. well the sub was in my old car and was working fine so im fairly sure its working. i havent played around with different thing yet as i thought i would see what you guys on here thought first but ill try and run the sub off the 4 chanel amp bridging 1 and 2 tomoro.
    cheers for the help mate.
    VY S soon to be SS
    Feb 2009
    NSW
    Quote Originally Posted by holdenboy View Post
    yep all the gear was installed by a local guy, but even he couldnt wok out why this wasnt working and yep im firly sure the sub is working. ill test it on a diferent amp soon.
    thanks for the help.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Just make sure the subs' internal wiring (from the subwoofer itself to the inside of the terminal board) is connected fine.
    Also try plugging in the RCAs from the sub amp into the speaker amp, if you get atleast low frequencies out of your speakers then the RCAs/head-unit are working fine.
    vt clubsport 5L 195i
    Apr 2009
    brisbane
    i remember this hapend 2 me in my vs,i thort i had it all hooked up properly but missed 1 wire the blue 1 that sed remote runs from head unit 2 the amp,after that it was pumping
  1. Running in oil??
    By frenchyvh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-03-2007, 08:37 PM
  2. EB 302 running hot
    By hispeedvp in forum V8 Development and Modification
    Last Post: 03-01-2007, 06:03 PM
  3. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  4. Vn V6 Running
    By cohn in forum Parts And Other Items For Sale
    Last Post: 18-07-2006, 09:52 PM
  5. v6 only running on 5
    By vnrock in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-08-2005, 01:58 AM
