Hi, i installed a pioneer FH-P6050UB double din car stereo into my vz ss using the DNA Audio adaptor plug and i set my settings and radio stations but as soon as i turn it off then on again it's all been reset!! Please help me!
you may have not connected your constant 12v and accessory wires the right way round
yeah mate the 12v consatant and acceseries is the wrong way around, had the same problem wen doing my mates vy allthough im fairly sure tis actually a fault on the adapter ie theyve mixed up the colours of the cable. so jsut switch those around and you should be sweet
Nearly all adapters you buy have the Constant and accsesries around the wrong way, you'll have to reverse them. Not sure if the VZ has a power antenna, check also to see if that's working because thats also another common problem with the adapters.
