Results 1 to 10 of 10
Thread: Will this blow my speakers?
    VL Executive
    Feb 2009
    Craigmore SA
    Default Will this blow my speakers?
    hey guys,
    i have a pair of pioneer 6x9 40 rms that i want to hook up to a pca4.400 amp which pumps out 60 rms @ 4 ohms. Would this blow my speakers? i also have a pair of pioneer 6x6s 50 rms in the front, would i be better hooking up to them because the rms values are closer. or is that worse because they are only 6x6s?? A friend of mine said the 6x9s would be fine but i want a second opinion
    thanks
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    Not sure on the amp but if its 2 channel use the 6inch up fronts, if 4 channel connected the 6x9 as well set the frequency/gain accordingly for the lower spec speaker (if you can)
    VL Executive
    Feb 2009
    Craigmore SA
    yeh its a four channel but i already have two channels hooked up to a sub, so better of hooking the 6x6s up before the 6x9s?
    SMIT's Avatar
    Aug 2005
    if you have a sub i wouldn't evan connect them, this way you have a better selection of frequencies playing. Just go the 6inch and subs
    VK
    Jul 2004
    if you connect em and set the gain and filters correctly you wont blow them
    Stressball's Avatar
    Stressball is offline Rolling on 4 again :D
    Mitsubishi Triton
    Oct 2005
    SE QLD
    The power difference is fine, if your speakers are 40wRMS per channel, 60wRMS per channel in will be fine. Overpowering speakers is a hell of a lot safer than underpowering, just make sure you never do that
    As Kinkbike_rider said, 6x9 speakers are generally used where you don't have dedicated low frequency channels. Since you have a sub, you would be fine with the 6" speakers without the 6x9"s.
    VK
    Jul 2004
    Yea like everyone is saying, itd be more preferable to amp the fronts, as that's where you are going to be sitting. If you really want to amp the 6x9s, set you high pass filter to around 100-120Hz, your sub will take care of the frequencies below it.
    commsirac is offline Banned
    vx
    Aug 2007
    As has been said ^, more amp power than you need is never a problem, just refrain from turning up the volume too far. A lower power amp wont suddenly stop powering the speakers when you turn up the volume, it will keep getting louder too, but with damaging high frequency signals that will burn out your high frequency units without you even knowing it.
    VL Executive
    Feb 2009
    Craigmore SA
    ok thanks guys, i recon i'll keep the 6x9s though, i dont want it to sound like all my sound is coming from the front of the car, keeping the 6x9s gives it that surrond sound feel
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Quote Originally Posted by owen18 View Post
    ive had the same sony hd for a few years now connecte to 4 x 6x5s and 2 x 6x9 with twin woofer and 2 amps, it go's hard and its still going hard.. i even got a spare hd unit ive never had to use.... just tune the speakers in correctly depending on your setup and youll be right.. my 5th and 6 speaker dont kick in until i crank it up 16 i think.. all cost 400 bucks.. if u read the manuals and do some research on other pages in this forum section you'll get something mad happening bro... i wouldnt know if mines under or over powerd, still go's hard and hasnt stopped yet.. thumps the ground on the lowest bass setting dont bother using speakers for just bass, leave that to the woofers..
    ps. next im adding another 2 smaller ones in the dash
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
  1. blow your mind (speakers)
    By wickedVH in forum Car Audio
    Last Post: 25-11-2008, 06:50 AM
  2. Help vn 5.0 blow by
    By calais_8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-06-2008, 11:24 PM
  3. How to blow 5k on a VN S1?
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2007, 11:07 PM
  4. will this blow my sub
    By lieos in forum Car Audio
    Last Post: 27-08-2006, 03:29 PM
  5. so will a jaycar amp blow up when I...?
    By bezz in forum Car Audio
    Last Post: 22-05-2006, 01:13 PM
