Results 1 to 12 of 12
Thread: 2 Amps 1 sub wiring
    korn3172 is offline Chaps
    VT Commodore 2000 Olympic ED
    Aug 2008
    Default 2 Amps 1 sub wiring
    Ok,
    I have 2 pioneer GM-D8400M amps which are rated at:
    300rms/600w @ 4ohms
    600rms/1200w @ 2ohms
    Im looking to wire both of the amps to a single sub so wiring each to a single coil.
    Im guessing that if i do that, then i need dual 4 ohm subs. Which means each would wire at 1200w/600rms. For a total of 2400w/1200rms.
    The subs im looking at are 15" or a 12" Alpine type X
    1. Rockford Fosgate T215D4
    4 Ohms x2
    2000w/1000rms MAX
    2. Alpine Type X SWX-1243D
    4 Ohms x2
    3000w/1000rms
    3. Kicker CompVX CVX15
    4 Ohms x2
    2000w/1000rms MAX
    4. Earthquake Subzero-15
    4 Ohms x2
    2500w/??? rms
    They are the subs im thinking of.
    But does anyone know if using the 2 amps in such a was is possible?
    Has anyone done it before?
    Let me know
    Thanks
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I don't think you can run a subwoofer in stereo like this. Only amps with a 'link' connection can be used to power one subwoofer, and even then you want a dual 2 ohm woofer to get the most power out of them.
    Ronald Reagan (1986)
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yeas as long as its duel voice coil sube it can be ran off 2 amps my last sub even had a wiring diagram of how to do it with it.
    VK
    Jul 2004
    Yea it can be done... would be a lot of fun trying to get the gain settings right considering you're using two very different amps. Also, you'd want dual 2 ohm subs to present a 2 ohm load to each amp. Check out maybe a DD 3512 or Hifonics aswell.
    Aug 2008
    Hmmmm. BTW the amps would b the same. Cant remember what the guy at the audio shop said, but i need something else to do it. And the load from my amp would b 4 ohms anyway so scrapping the idea.
    New idea, 2x Alpine 15" 500rms subs
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yeah theres no point in going with a 4 ohm DVC sub, as both amps will only put out 300wrms each (600 total). If you were to wire the voice coils together and ran it off just one amp, it would produce the same power, so it kinda defeats the purpose of using two amps to power a 4 ohm DVC sub.
    Ideally you want a 2 ohm DVC sub or 2 x 4ohm DVC subs. So you can provide each amp with a 2 ohm resistance which will give you your 1200wrms.
    Also gotta consider the room the box will take up. A box for a single 12" subwoofer will be 1.5 (sealed) to 3 (ported) cubic foot, whereas a box for 2 15" subwoofer will need to be 3 (sealed) to 5 (ported) cubic foot. Theres a HUGE difference in between the two options, not even taking into consideration the cost of 2 15s over a single 12/15.
    Yes, i wont disagree that the 2 15s will "probably" play louder and lower (depending on box). But theres always the fun of giving it a demo to some people or mates, letting them guess whats in the boot and the shock on their faces when its only a single 12/15and they guess 2 12s or 2 15s
    In my opinion, go with a single 12 or 15" version, dual 2 ohm voice coils in a properly tuned ported box. With that amount of power it'll blow most people away with dual 12s or 15s.
    Edit: bezz, i think hes using two GM-D8400M amps.
    150db in a commodore =
    Aug 2008
    VX Berlina
    Apr 2007
    Oh well guess I was wrong. I've been told that unless the settings are dead on matched it could hurt the sub. Doesn't bother me I've got some amps that can be linked, tuning made easy .
    Just as I was typing this I thought 'how funny would the sub look if you had one amp with the phase reversed'?
    Mike S is offline Car Audio Pro
    Jul 2005
    I've seen this done using two crossfire 1000w D class amps, remember them, and a dual coil Kicker 12" sub. It was in a sealed box of medium size and was sealed so tight he reckons you could stand on the cone although I never saw him do it. Sounded awsome, probably the biggest bang I've ever heard from a single 12.
    If I was you Korn I'd do it, I reckon it'll work great. Just keep in mind that you'll need to put identical signals into each coil so if your using stereo outputs bridged then you need to put a stereo signal into each amp so you get a mono output into each coil.
    It looks like you'll need a DVC x 2ohm speaker if you plan on using the pioneer amps.
    Mike
    Aug 2008
    Quote Originally Posted by acarmody View Post
    Yeah that makes it easy for you,
    the problem with mine is that i need a "Sync" or something. There is a techincal term for it. Basically sets the gains the same
    VX Berlina
    Apr 2007
    I've never heard of Pioneer having any sort of "Sync" device, but then again I've never really looked. I think some of thier top of the range Premier series can be linked with a cable. I'd just make sure I'd use a really good car audio tuner to make sure the settings are dead on.
    Aug 2008
    Nah its not from pioneer, its just a piece of audio equipment i think.
LinkBacks (?)
  1. 18-07-2009, 01:00 PM
  1. i need a wiring diagram for to amps
    By mundine in forum Car Audio
    Last Post: 12-03-2009, 04:23 PM
  2. Wiring up 2 amps????????
    By DarkCrystal in forum Car Audio
    Last Post: 22-04-2008, 03:08 PM
  3. how do i run two amps?
    By Haydz in forum Car Audio
    Last Post: 04-01-2008, 01:12 PM
  4. Amps
    By ducatis in forum Car Audio
    Last Post: 27-07-2005, 03:15 PM
  5. Amps/Subs/Speakers wiring
    By tr3nt in forum Car Audio
    Last Post: 07-07-2004, 12:37 PM
