Results 1 to 5 of 5
Thread: power cable burn?
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    Default power cable burn?
    ok so today i pulled my subs and amps out as i am going camping for the long weekend!!
    not the funnest job by yourself either!! 2x pioneer premiers wayin in at 12-15kgs each and the weight of a dual box and two large amps=heavy!
    after pulling them out i pulled my power cabls back through the bottom boot liner...(cables are 0guage to distribution box then to 2 4 guage) and where the cables go, the sub box has been laying on them and the cable has sorta black burn marks in the insulation(see-through red)!
    its 4 guage and the amps are 1000rms each...so would the cable still be safe or should i get new stuff and re-route my cables around my box!
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    ve ute 22's lowered hardlid
    Apr 2009
    newcastle
    sounds like the cables arnt big enough and they have been over loaded, hence the burnt black area.. thats just what i think?
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Are both of the 4G cables independently fused? If they aren't then you can still overload them without overloading the 0G or tripping the fuse on the 0G.
    If they are, then it's possible that the weight of the sub has worn down or pierced the insulation on the 4G cable enough to singe the insulation but not draw enough current to blow the fuse.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    0ga is more than enough for that power... Even 4ga wouldn't go black with 1000Wrms.
    It'd be from the rubbing.
  1. vs amp power cable
    By jfresh in forum Car Audio
    Last Post: 24-03-2008, 02:23 PM
  2. VT amp power cable
    By danx in forum Car Audio
    Last Post: 15-07-2006, 05:21 PM
  3. power cable
    By matrix in forum Car Audio
    Last Post: 28-03-2006, 10:35 PM
  4. Power Cable
    By Brycestro in forum Car Audio
    Last Post: 25-03-2006, 02:26 PM
  5. Red and green, next episode..Burn BAby Burn
    By The1985divo in forum Jokes/Humour
    Last Post: 08-08-2004, 09:01 PM
