Hi
i have been looking at getting a Capacitor but an not to sure im running
Sony Explode Headset
MTX 6" Thunder splits for the front
MTX 6" normal speakersfor the back
MTX 12" Sub
MTX X300D 300 watts ClassD Amplifier
MTX X704 280 watts 4 Channel Amplifier
at the moment. i dont really know a lot about capacitors im just looking for some advice.
its been covered hundreds times do a search
and no ya dont need one they are a waste money
Honestly mate, capacitors have more of a "wow" factor rather then a useful addition to a system. Youre money is better spent on a better battery and/or upgraded wiring.
150db in a commodore =
Unless your experiencing any problems such as headlights dimming as a result of the power being drawn from your battery, then as stated above, they are a waste of time and money.
Even if you get headlight dimming, you'll find a capacitor wont help all that much. As i said, better battery and upgraded wiring should dramatically reduce or eliminate headlight dimming.
my battery has decided to start playing funny buggers with me today so im gonna get a new one, what would you recommend? i dont want anyting to expensive
Are you a member of NRMA? if so, they offer a replacement battery for $99, i think it's a 460 CCA. I just replaced my battery with a 440 CCA,which i thought was a little under what i should have got, but i haven't had any problems yet, and i run 2 x 2 channel amps, 1 x Monoblock, Splits, 6x9's, and a sub...Also, another idea, if your not a member of NRMA ect, car delearships, when they sell a new car, they remove the battery and fit a new one, and quite often will sell the old ones. I picked up one, which would have only been a few months old for $50-
autobahnnnnnn are doing 600cc for 99 bux atm normally 169
i got mine when it was 169 few days b4 the sale heaps powerfull battery
