Results 1 to 20 of 20
Thread: what is the best?
    VY S
    Apr 2009
    ACT
    Default what is the best?
    hi,
    i have a Vy commodore
    i buy a polish thing from Big-w and i polish the car myself
    i wonder if that harms the paint?
    if anyone uses it please say here
    and if it does then what is the best product to use
    also what can i use for interior to give it that shiny look,?
    thnx
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    VT spac super6
    Nov 2008
    Riverton sa
    i use turtle gear normally..
    doesnt matter what it is, long as your using a good clean soft rag and the car is clean it shouldnt scratch it..
    armoral will make the interior shine (y)
    NIXONLS1 is offline Banned
    my mum
    May 2009
    Bansville
    Oh dear lord, yeh get the polish thing and buy some stuff and make it spin on the paint.
    VY S
    Apr 2009
    ACT
    Quote Originally Posted by HoldenOnn View Post
    A polish thing?
    sorry
    itz called Polyglaze (Cut & Polish)
    and what i was askin is if i keep using it will it fade or effect the color of the car?
    thnx
    VY S
    Apr 2009
    ACT
    Quote Originally Posted by HARVZ-6 View Post
    thnx for the suggestions mate
    VY S
    Apr 2009
    ACT
    Quote Originally Posted by NIXONLS1 View Post
    thnx
    HoldenOnn's Avatar
    May 2009
    Busselton, WA
    Log onto the sponsor's site; Car Care Products / Car Care, Car Wax, Car Polish, Car Covers, Detailing products & more ...
    Zaino, Dodo, Duragloss etc are just a few of brands of products which are better than most of the retail outlet bought products.
    the collector is offline the collector
    rodeo dual cab
    Mar 2009
    adelaide
    Default polish this
    no offence but if your asking then you shouldnt be doing it!!!
    machine polishing a car correctly is not easy.
    but its very easy to cause thousands of dollars of paintwork damage in seconds
    a full cut and polish from a crash shop with paint protection can be had for $250-450.
    expensive ,not really,if they **** it and buff through your edges they paint it.(check before)
    if your still keen just get some good hand polish meguires/geelson/3m and do it yourself by hand and be safe
    good luck
    cheers
    vx commodore v6
    Jun 2009
    rowville
    turtle waxs ice range is the best by far!!!!!
    and im not just gettin that off blood sweat and gears
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Quote Originally Posted by the collector View Post
    but its very easy to cause thousands of dollars of paintwork damage in seconds.
    Agreed. It's best to have a go on an old spare panel first. Proper machine polishing removes a layer of paint (with an abrasive polish) from the paint work. Machine polishing can build up quite a lot of heat - if you're not careful you can burn through the clear coat and you'll have to re-spray the panel.
    Also a random orbital polisher is much better for a newbie then a rotary polisher because it builds up less heat.
    For polishing by hand, nothing beats Autoglym Super Resin Polish, you can find it at Autobarn. It's filler heavy (fills up the scratches with a resin) so you get good results without much effort. Top it off with a good wax/protectant (e.g. Autoglym Extra Gloss Protection) otherwise the fillers will wash away and you're back to square one. Over time the fillers will wear off and the scratches will come back, so you have to polish again but that's the trade off.
    You can use abrasive polishes by hand which provides a more permanent result, but your arm will be very very sore after doing a whole Commodore and you'll be polishing all day to get decent results... You probably won't be able to remove bad scratches by hand, but light swirls can be removed quite successfully.
    I use a meguiars applicator pad (the yellow foam ones) to polish, and a clean microfibre to buff.
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Car Care sells excellent random polishing machine, the Megs 220 is a good a excellent start with the Menzerna polish samplers. Enough to fix your car up for years. You only gonna polish with machine once a year if you wax and maintain properly, if that even.
    Lots
    Jan 2009
    Rozelle, Sydney
    First up the 'stuff / Cut n Polish' is probably not the best especially if you paid about $10-20 for it. As it is a cut and polish, it will 'cut' your paint, so will remove some it each time you polish. If you are having to do this more than every 6 months it is not working.
    TMM above came up with some good options. If you are looking for good results by hand then a great start is the Autogylm Car Care Products / Autoglym / Detailing Kits / All Categories / Paintwork Perfection Kit for a little over $40 (remember your discount) you are in business. For light marks or for spot 'cutting' the Paintwork Renovator works, then the AG Super Resin has a very light abrasive but good filling and the Extra Gloss seals.
    Otherwise if the paintwork is in fairly good condition and you are just looking for shine and protection then Duragloss is another great product and value for money at again about the $40 mark. You can use the Car Care Products / Duragloss / Exterior / Polish - Cleaner/Wax / Polish and Cleaner on its own ($20) or if you want the protection to last longer combine it with Car Care Products / Duragloss / Exterior / Polish - Cleaner/Wax / Polish Bonding Agent
    And as vxcalais01 says - if you want to correct your paint properly then a machine polisher is the only way - your are talking more money up front but then it is 'fixed' or you find a good detailer who will machine polish it and you can then just wax/seal to keep the finish.
    As for making the interior shiny - see the plastics thread in this section and the comments but for the same money as the a***all (in the black bottle) you can get the good stuff instead - Car Care Products / 303 Products / Interior / Dash & Trim / Aerospace Protectant The 303 will NOT make the surface greasey, attract dust, it does not contain silicones or solvents that will ultimately dry out and possibly crack plastic.
    Hope this helps
    Car Care Products Australia
    www.carcareproducts.com.au - 1300 006 007 - info@carcareproducts.com.au
    Do you care for your car?
    For Special Promotions, Exclusive Deals and the Latest New Products follow us on Facebook
    rodeo dual cab
    Mar 2009
    adelaide
  15. #15
    VP Berlina
    Mar 2009
    For a nice and shiny interior, use Armor All spray.
    It's also good to bring out dull black plastic bumper bars, moulds etc..
  16. #16
    rodeo dual cab
    Mar 2009
    adelaide
    Default armor all
    armour all is shit,its nice and shiney but full of silicone and farked for paintwork in the future
    use silicone free always,be kind to your repairer
    cheers
  17. #17
    Lots
    Jan 2009
    Rozelle, Sydney
    The only product to use on your interior and exterior plastics is 303 Aerospace Protectant:
    It has an anti UV property that will stop plastics deteriorating in the sun. It is silicon free and will leave a nice as new sheen on the dash.
    Cheers Greg
  18. #18
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride
    VZ S ute
    Jun 2009
    Port Melbourne
    If you really want to waste your money, buy Zymol products, they're all natural and smell like fruit and chocolate. It is the best of the best. It lasts for 6 months and all you need to do to make the paint shiny again is wipe it with a cloth.
  19. #19
    Jan 2009
    Castle Hill
    Quote Originally Posted by v8freak55 View Post
    What makes them the "best of the best". Also what one were you using that lasted 6 months?
  20. #20
    VE SSV A6
    Apr 2009
    South Aust
    Collinite 476s it lasts up to about 12 months
