Results 1 to 14 of 14
Thread: Hey
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Default Hey
    hey there
    whats the best scratch remover in the autoglym range, i just need to remove them light swirls out of a clear coat on my black ute
    ive tried meguiars and mothers scratch remover and they didnt do anything so i need to be 100% sure it will remove them, i dont wanna waste money
    also i do it by hand too
    thanks
    VX Berlina
    Mar 2006
    Trying to remove swirls by hand is a waste of time unless they are very very light. If the Megs & Mothers failed, I dont like your chance of removing them by hand. The only thing Autoglym have is SRP which hides them with fillers(to a point), not remove.
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    VX Berlina
    Mar 2006
    Quote Originally Posted by Wavez View Post
    Try Auto Glym 02B first, if that doesn't work try the 03B.
    No way you will break them down by hand. Well you may but jeez you will have a sore arm
    Lots
    Jan 2009
    Rozelle, Sydney
    Ho light are the swirls? What one person calls a swirl, another calls a scratch?
    Quote Originally Posted by VicVXBerlina View Post
    This advice is all true but Autoglym Paint Renovator is more agressive than SRP. It can be hand applied and will remove light swirls:
    Car Care Products / Autoglym / Exterior / Surface Prep / Paint Renovator
    Another point is that you should be using Ultra Deep Shine not Super Resin Polish on dark cars. If you are using Paint Renovator, you will need to follow it up with SRP or UDS:
    Car Care Products / Autoglym / Exterior / Polish / Ultra Deep Shine
    02B is the trade name for Paint Renovator ^ above. 03B is a trade polish for machine use only.
    Car Care Products Australia
    www.carcareproducts.com.au - 1300 006 007 - info@carcareproducts.com.au
    Do you care for your car?
    For Special Promotions, Exclusive Deals and the Latest New Products follow us on Facebook
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by Car Care Products View Post
    hey mate
    yeah ive used the ultra deep shine
    that paint renovator with the pink label can it be used by hand? and shud clear the clear coat up nicely?
    thanks
    Chirpstr's Avatar
    Sep 2007
    Quote Originally Posted by WogBoyz View Post
    hey mate
    thanks
    No, 02B Ultrafine Renovator is a yellowy/orange colour. Its a 50/50 chance of it actually removing swirls by hand... It all depends how bad they are.
    Maybe upload a pic.
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Chirpstr's Avatar
    Sep 2007
    so what does the pink one do then?
    This one you mean with pink label? Car Care Products / Autoglym / Exterior / Surface Prep / Paint Renovator
    It's the same as 02B as Car Care Products said.
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    yeah thats the one, so it can be used by hand fine?
    VX Berlina
    Mar 2006
    Yep! it can be used by hand. My statement with it not working was based on the other products not working and you needing to be 100% sure it will remove them & doing it by hand I dont think anyone can give that guarentee when doing by hand. as said by Wavez pics would be good.
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Lots
    Jan 2009
    Rozelle, Sydney
    It is hard to advise what level of correction can be achieved (especially by hand) without seeing the actual paint.
    I have had customers expect to hand polish out marks that were though the paint layers (you could see the white primer layer). You may achieve a decent result but hand applicable products with micro abrasives may need multiple applications to completely remove the defect. The polishing ability of a hand applicable product may be diminished by any protective layers already on the paint. Most products will have a combination of cleaning agents and micro abrasives and I have seen a few cases where the first application is only cleaning off old wax or sealant layers but the second application will start to correct the clear coat layer.
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    kk its not real bad just light swirls, im getting a detailer to have a look at it on sunday, so ill see what he says and report back
