Results 1 to 6 of 6
Thread: Water Marks in the Clear Coat
    SV6 Commodore 6sp man
    May 2007
    Default Water Marks in the Clear Coat
    Hi, how are you?/
    my black 2006 car has just been washed, colour cured and slightly clay bared. The problem is that even though clay bar has been usd and colour cure, when the car is dried with a chamois in certain light it looks as though there are water marks all over the paint, it is as though the water mark is embedded in the clear coat. Any idea on how i would get rid of that and a suggestion of product to use?Thanks
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    I am also having this issue. I can spend 2 hours rubbing with a clay bar and they will still be there.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You will need a fine cut polish to get them out. There is another thread titled "Crying about my clear coat" that has the same issue.
    Visit my Facebook page
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Quote Originally Posted by Not_An_Abba_Fan View Post
    I pretty much fixed the majority of the issue with meguairs swirl remover 2.0 which is a very light product. Looks much better.
    Y-Series Senator Signature
    Jan 2006
    Willall Racing
    VL Calais Turbo
    Nov 2009
    Quote Originally Posted by Vee-ard View Post
    I had the same problem. They had etched into the paint and the clay bar did nothing. I used this car polish which is only a light product but removed the marks and left the paint looking awesome.
  1. Clear coat peeling
    By azzfox in forum General
    Last Post: 26-09-2009, 01:03 PM
  2. bad clear coat
    By reidy1990 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-08-2009, 08:45 PM
  3. Clear coat respray
    By stocky in forum General
    Last Post: 22-03-2009, 09:30 AM
  4. Cut & Polish V Clear coat
    By MG's VH Wag in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2009, 09:33 AM
  5. Lifting Clear Coat!
    By sheapard in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-06-2008, 01:07 AM
