Results 1 to 13 of 13
Thread: Clay Bars?
    VT S2 Club Kitted, VR SS, VL Executive
    Oct 2005
    Broken Hill
    Question Clay Bars?
    My mate was talking about how he "claybarred" his car and it came up real good, i dont really understand it (read the tut on how to do it lol) but is there different grades etc? example: Sandpaper grit?
    I have a 1995 vr ss commodore and the paint needs a little bit of love, heres some pics, so i can order the right one.
    Thanks for the help - Hendo.
    Pics have been taken in beauty mode on camera, so every imperfection shows up :P
    As you can see every little detail of the car has came up, but yeah i still goto fully remove that black glue strip, ill do that this w/e when i recieve this clay bar im about to order heh :P
    2010 Isuzu FXZ 1500 on 20's
    Oct 2006
    Bogan enclave
    Clay isn't going to remove that. I think you need to do some research so you know what clay is and is not capable of. Most of that white residue looks like old dried polish that will simply wipe off. Don't attempt to remove that glue with your clay bay as you'll simply destroy it. (The clay bar.)
    At this stage you'll get more results from giving the car a proper wash. Everything looks pretty dirty.
    Oct 2005
    Broken Hill
    Yeah the actual blemishes and swirl marks ain't actually showing in the photos, and everything that is not supposed to be showing up is because of the "beauty shot" on the camera lol
    Edit: i Wasnt going to use the clay bar to remove the black strip, only wanted to know if they remove blemishes and swirl marks pretty easy, and if someone could tell me what one to buy.
    Oct 2006
    Bogan enclave
    Ok then. Just wanted to make sure you weren't getting the clay to remove all of that! Also clay won't remove swirling. What clay will do is remove contaminants embedded in the clear cloat. Also be careful with claying as there is a high chance of marring. Not really problem if you plan on polishing afterward. But if you're not you need to take care.
    Example of marring...
    And a shot of clay after use...
    Oct 2005
    Broken Hill
    ooo ok, i've got a better understanding now :P, so really you clay the car? then give it a good polish?
    Is mcquires wet look a decent polish, as i have been using it for a couple of years now and personally like it, are there any better ones so when you look at the car it's like "wow".
    VT V8 Calais
    Mar 2007
    You use a spray on lube with the claybar, this allows it to slide over the paint.
    50LTRv8
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Quote Originally Posted by 50LTRv8 View Post
    I just use it whilst i am washing the car and its all soapy?
    VT R8 S2
    Oct 2008
    no you gotta wash the car and completely dry it first, then you use the lube to help the clay glide over the paint and pick up contaminents. normal soapy water isnt enough lube to get it working optimally itll stick and leave clay residue on your paint also probably take you so much more longer since the soaps will dry up
    Oct 2005
    Broken Hill
    Are there different types of clay bars, like grit on sandpaper for example?
    GAMBLR's Avatar
    GAMBLR is offline More trouble than u think
    '04 VZ Calais LS1
    Dec 2006
    Whyalla (yawn), South Australia
    Clar bar won't remove swirl marks and scratches buddy, as they are in the clear coat.
    Clay bar is used to remove contaminents on the paint surface, so tree sap, road grime, bird fallout etc. Thats the dirt-looking stuff on the bar in the above picture. It preps the paint for cutting or polishing, which will help in removal or reduction of swirls.
    CruznCalais
    [GAMBLR]
    The VZ is here! About time!
    Oct 2006
    Bogan enclave
    Quote Originally Posted by blky View Post
    No need to dry car to clay but yes you require some kind of lubrication. Some people use a wash solution as lubrication but the cleaning agents in the wash solution tend to break down the clay.
    Quote Originally Posted by ::Team420:: View Post
    Yes there are different grades of clay. Stick with fine or extra fine otherwise you're going to introduce some serious marring. Claying will also remove any sealant (if any) you may have so this will need to be reapplied.
    Oct 2005
    Broken Hill
    Quote Originally Posted by Bravotwozero View Post
    Thankyou thats what i needed to know lol ill just get a "fine" one then polish i guess. Time to go order.
    Lots
    Jan 2009
    Rozelle, Sydney
    This is a good clay for a starter Mint Clay and Magic Lube for more info on claying your car see here: How To Clay your Car
    Like the guys have said it does not remove scratches, swirls, dents or glue - it is however a very important stage before polishing or waxing to remove contamination that usually you cannot see. So
    Wash (really well, a stronh wash if you have one)
    Dry (or rinse well and leave if your water is ok and in the shade)
    Clay
    Polish (removes swirls etc to 'correct' paint)
    Wax/Seal to protect your paint.
    Car Care Products Australia
    www.carcareproducts.com.au - 1300 006 007 - info@carcareproducts.com.au
    Do you care for your car?
    For Special Promotions, Exclusive Deals and the Latest New Products follow us on Facebook
  1. clay bars
    By kniever in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2007, 01:54 AM
  2. clay bar
    By Troy711 in forum General
    Last Post: 13-12-2007, 02:49 PM
  3. clay bar or not?
    By cxcxcxvcvcvc in forum General
    Last Post: 30-09-2007, 08:06 PM
  4. I Am Now The Biggest Supporter Of Clay Bars!!!!!
    By AirStrike in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-04-2007, 06:40 PM
  5. Post Pics Of VR - VS Custom Front Bars (or Clubby front bars)
    By Australian&Antichrist in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-09-2005, 05:08 PM
