hey guys, i have just purchased the above clay bar kit from super cheap auto, and was wondering as a novice when it comes to clay barring a car am i goin to run into any trouble with this kit eg; is it a cheapo kit? have people had problems with it?
also i picked up a rockwell shopseries rs450 orbital polisher which i intend to use with the polyglaze cut and polish i already had at home, is this a good combination?
and finally can somebody recomend a good wax, eg; brand, and so on
thanks
james
The Rockwell will be useless with paint correction with only 130w. Anything under 400w isn't enough power imo.
As for the clay I haven't used Mothers products before. Wouldn't have been my first choice though. There are plenty of waxes available that are a good price. Guess it depends on what you want in terms of durability versus shine.
Personally I use P21S 100 over a sealant but you may not want to spend that much. What is your budget?
You may want to try something like Duragloss Aquawax. At just over $20 it represents good value. Will also give you a nice balance between protection & shine. Just remember that a little goes a long way. One squirt per panel will suffice. Then simply wipe down with a good quality microfibre. Also with claying be very very gentle and make sure you use plenty of lube. Having a dark coloured car will make marring from claying very noticeable!
Car Care Products / Duragloss / Exterior / Wax - Spray / Aquawax
Yeah I'd return it. If you don't want to spend a few hundred on a more powerful machine then you're probably better saving the money and doing it by hand. Machine polishing is a pretty expensive outlay. On top of the machine you then need to buy pads. Which you then need to work out which pads to buy. Can do your head in when you're just starting. I've already bought 2 RO's this year and am now looking at my 3rd machine. My wife is going to kill me.
Do yourself a favour and take the 'cut and polish' back at the same time, again a very average product.
If you don't have the funds for a decent RO polisher, pads and polish (around $350 complete) then why not try DG Pre-Cleaner followed by DG Polish and Cleaner this combination should sort out light swirls and enhance the shine/gloss. Then for regular washing as suggested above get a bottle of DG Aquawax it will offer ongoing protection and shine and should last at least a year for weekly washes. You will get 100 times the results than off-the-shelf products and for not much coin.
Hope this helps
Car Care Products Australia
www.carcareproducts.com.au - 1300 006 007 - info@carcareproducts.com.au
Do you care for your car?
For Special Promotions, Exclusive Deals and the Latest New Products follow us on Facebook
That's is the point - you don't have to.
If you use the DG Pre-Cleaner and then Polish and Cleaner once (time about 1-2 hours) then you have the paint cleaned up. If you use the Aquawax when you dry your car after a regular was (time about 2 mins extra) then it will add to the protect. If you can clay and reapply the base product every 6 months it would be great, if not as long as you are using the Aquawax then it should be good for 12 months. Not much time (2-3 hours per year min) or investment (under $100), but it should look after your investment (the car) a lot better than anything mentioned in your original post
iwill give it ago soon so how it works out
