Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Detialing a Commodores engine?
    vz commodore lumina
    Jan 2010
    sydney
    Default Detialing a Commodores engine?
    hey guys just want to know what i should be using etc to detial my engine, mostly because the bonnet was left open last sandstorm we had and its pretty dirty
    what should i be using for the engine, the engine cover etc?
    Lots
    Jan 2009
    Rozelle, Sydney
    Hi,
    We are putting together a guide on this very soon (2-3 weeks) to make it easy.
    But basically you need somthing like:
    Mint APC
    Spray Bottle
    Brushes
    303 Protectant
    A couple of plastic bags or cling film
    Pressure Washer preferred if not fine spray nozzle on hose
    Then:
    Open bonnet and cover anything delicate, alternator, electrically boxes etc with plastic bags
    Spray lightly over the engine and front guards.
    Use the APC at a dilution of 1 to 3 parts water and spray all over the inside bonnet first
    Aggiitate with brushes and rinse lightly off
    Spray over motor and aggitate with brushes
    Lightly rinse off and guards as well
    Take away plastic bags and start motor
    Run for 5 minutes and then switch off
    Spray 303 liberally over the hoses, plastics etc and work into all areas with an old cloth
    Clean, dressed and shiny engine!
    Always keep the pressure washer or hose nozzle about 60+ cms away from the motor.
    Watch out for video but in the meantime but hope this helps.
    Car Care Products Australia
    www.carcareproducts.com.au - 1300 006 007 - info@carcareproducts.com.au
    Do you care for your car?
    For Special Promotions, Exclusive Deals and the Latest New Products follow us on Facebook
    VS Statesman 3.8S II
    May 2010
    Melbourne, Vic
    I am interested but you have no video.
    Link me when you got it, and would'nt mind having a look at some before and after results of this engine bay cleaning kit you have assembled.
    1997 VS Statesman 3.8S Series II
    Cashaz' 97' Statesman
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    what would you suggest if the motor is somewhat oily? .. some kind of degreeser?
    old was a VY R8, 200sx daily. bring on the elsie!
    Aug 2010
    central coast
    to clean my motors i would just own the engine bay (alternator and all) with 2 - 3 bottles of degreaser then hit it with the pressure washer.. never have any problems cheap and easy and SHINY
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
    Quote Originally Posted by STEEV888 View Post
    +1 for 3bucks worth of degreaser and a pressure washer, but i usually keep the engine running while i do this
    May 2004
    I don't use any bags either but just be mindful of where you spray the degreaser as you can wash the grease out of things like idler pulley bearings and the alternator bearings and then have a noisy engine! Also make sure the engine is cold enough to touch before you hose it as rapidly cooling a hot engine is not a good idea.
    VLC86's Avatar
    VLC86 is offline ..stay N/A..
    VL Calais
    Dec 2009
    Quote Originally Posted by Jacko84 View Post
    Why do you leave it running while your cleaning it? I have never heard of this before
    Aug 2010
    central coast
    Quote Originally Posted by VLC86 View Post
    so he knows when he has F@#&ED it and can stop hahaha.
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Lots
    Jan 2009
    Rozelle, Sydney
    Turn the engine off while cleaning / degreasing otherwise it is too hot and the degreaser will dry instantly and permanently stain most metals, rubbers and plastics.
    And like a couple of guys have said cover the alternator, just to be safe.
    After you have rinsed the engine off, then start it up and run it for 5 mins.
    Stay away from Silicone spray, it might look good for a day or two but ultimately will perish yuor hoses try somthing like 303 Protectant to add some gloss to the plastics and hoses and actually protect them.
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    I once pressure-cleaned my 3.8L V6 (Toyota Lexcen). Period. Drove home and noticed an engine rumble and stutter; drove into garage for the night.
    Next morning: dead coil pack and a shorted alternator!! "Water penetration", sayeth the Wise Man with Sidchromes stuck in shorts.
    Bang goes $700 in fitting new bits. "Not happy, Jan!" (mechano man is a Pole and name pronounced "Yarn").
    Jan: What'd you put on the engine? This is bad.
    Me: Pressure wash at the drive-in up the road.
    Jan: Ah—, you know what...?
    Me: Hmmm?
    Jan: That did it!
    Me: *stunned mullet expression*
    Moral: No pressure blasting!
    Fast forward to a gleaming Alloytec (however did they get it so clean?), I give it the Mr Sheen treatment by hand (alloy bits respond well with Mr. Sheen) once a month. I use Maquires black plastic polish rejuvenator for the plastic bits. Experimented with Armoral spray inside and out but found it attracted dust and a disagreeable pong that reminded me too much of my old girlfriend.
    Curiously, I've observed early morning cleaners in local car yards using pressure cleaners on modern engines (the V6 I mentioned was from 1993, not an Alloytec wunderkind). Curious about that. Presumably they know what they are doing...?
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    VR Berlina
    Jun 2010
    VIC
    i have pressure washed many engines and theyre all fine. as long as u cover the alternator and be careful about spraying around the electrics its all fine
    Aug 2010
    Well, there's the behemoth of the alternator to cover, but no exposed contact electrics I can see, if that's what you mean. Big fat cables / connectors that fit exquisitely into places... the usual Holden prettiness. Anything under the black plastic covers that can be affected e.g. spark plugs, injectors et al? I'll experiment with putting a heavy weight canvas square draped over the alternator before I squirt the beastie, but would first want to wise up on anything that definitely should be avoided in terms of exposed electrics, visible or hidden.
  15. #15
    VR Wagon
    Oct 2008
    Central Coast, NSW
    I have been using Silicon spray in my engine bay for years and have never had any damage done to any plastics or rubber, I did the gf's car around 3 months ago and everything still looks great under the bonnet, Don't go nuts with it though give it a wipe over after afew minutes just to get the excess off which will stop dirt sticking to it as well.
    Cheers Josh
  16. #16
    2007 wm caprice
    Nov 2010
    cobar
  17. #17
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
  18. #18
    Lots
    Jan 2009
    Rozelle, Sydney
    Hi guys,
    We have not done the full write up yet but the video is listed here: How to - Engine Clean
    The full info will be on our How To Guides section on the website
  19. #19
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Cover the alternator, coil pack, fuse box, intake snorkel and battery. Try not to get too much water in the spark plug recesses when rinsing. It might help plugging them up with paper towel or some small rags. I think a regular hose on a fine mist setting is safer then a pressure washer.
  20. #20
    maka5's Avatar
    maka5 is offline -=U=-
    07 VE SS M6
    Aug 2010
    Melbourne,
  21. #21
    VX
    Mar 2011
    SA
    Quote Originally Posted by TMM View Post
    This is what im looking for however im not too mechanically minded and im unsure what things to cover, if anyone has a picture of a engine bay with the delicate parts that should be covered. would help out a lot
  22. #22
    VX Executive
    May 2010
    Mornington Peninsula
  23. #23
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    top of the motor on the front of the passengers side,3 black square things next to each other with 4&1, 2&5, 3&6 written on the top
  24. #24
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Or in simpler terms, they have the Spark plug leads coming off them. Don't know what spark plug leads are, then you probably shouldn't be cleaning under the bonnet.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
  25. #25
    Lots
    Jan 2009
    Rozelle, Sydney
    I would cover up your coil pack, and airblow to dry the engine to avoid any arcing from your plugs/leads.
  1. VT Commodores
    By Rossbx in forum The Pub
    Last Post: 27-12-2009, 03:35 PM
  2. VL Commodores
    By Mad-Biker in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-12-2009, 09:56 PM
  3. Hi all, new too just commodores
    By Dilweed in forum VT - VX - VU - WH - V2
    Last Post: 12-04-2007, 01:03 AM
  4. Just Commodores
    By Garth in forum General
    Last Post: 27-11-2003, 01:26 PM
Tags for this Thread
