Results 1 to 8 of 8
Thread: How many of you use Buffing Machines?
    VY ute (2003)
    Jun 2010
    Manly
    Default How many of you use Buffing Machines?
    Hey Guys,
    Quick question,
    I just spent about 5 hours cleaning my car yesterday (Don't ask) and i realised most of the time is trying to buffer off all the polish and wax.
    Having a broken finger didn't help ..
    I am looking into getting one of these to do a much better and easier job.
    Thanks!
    VE S2 SV6/A6
    Apr 2011
    I have a Random Orbital Sander (ROS) with varying pads depending on what I am trying to achieve.
    I hardly use it on the car though, only when I am trying to correct a paint issue.
    I use Dodo Juice soft wax on the car (from Car Care Products) every three months. Applied my my fingertips (yes my neighbours think I am mad) and a microfibre cloth to remove, doesn't take a lot to do if done semi regularly. My car only sees daylight for a couple of hours each day as it's either in the garage or an undercover carpark at work. I could probably get away with every six months but it always looks great this way and easy to apply/remove. After the wash, takes about 2 hours to prep the paint and apply/remove the wax.
    Current Ride: 2011 VE Sedan - In Voodoo of course.
    Last Ride: 2004 Subaru Liberty GT, Twin scroll turbo, tuned, Bilsteins, sway bars, no rice, 420Nm
    Also Own: 1964 EH Wagon, modified interior, minor modifications outside
    No
    Dec 2011
    sydney
    Quote Originally Posted by letthiswork1 View Post
    Hey Guys,
    Quick question,
    Thanks!
    A good DA (dual action) polisher makes life much easier, let alone the results.
    Working by hand is a very hard task if you want to correct your paint, or even apply sealant/wax at the end.
    I suggest you buy a descent polisher, with appropriate pads and compounds as it pays for itself on the long run.
    Don't go for the cheap ones you can find in auto shops for $40 .. its just waste of money.
    Lots
    Jan 2009
    Rozelle, Sydney
    Quote Originally Posted by Voodoo_SV6 View Post
    With the wax, it is best to apply by hand as i wouldnt recommend machine application at all.
    to remove the product you can use a Microfibre Bonnet over a buffing pad to remove the product.
    Car Care Products Australia
    www.carcareproducts.com.au - 1300 006 007 - info@carcareproducts.com.au
    Do you care for your car?
    For Special Promotions, Exclusive Deals and the Latest New Products follow us on Facebook
    TinSnips's Avatar
    TinSnips is offline Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    If it's taking a long time to remove wax residue, you're either applying it far too heavily or using the wrong product.
    As for polishing and compounding - you just can't do the same work by hand that a good machine does. They are irreplaceable. Definitely worth the investment. And to have a go at a DA machine, all you need is a hint of common sense. They're very safe.
    Xw GT replica/Vr s ute/Ef
    Jul 2011
    NSW
    Poliglaze cutand shine and nu finish polish after to get a awsome finish and by hand with rags ftw.
    No
    Dec 2011
    sydney
    Hey Guys,
    Quick question,
    Thanks!
    Usage of DA (dual action) polisher is highly recomended for both paint correction and wax/sealant applicatiion.
    You can realy achieve a good results with hand method, but hey ... Why waste your time, let alone the results.
    Using a DA in wax applicatioin helps with uniformed/even application of a product on your car.
    For wax application with a DA you can use Lake Country white pads, achiving amazingly even coat of wax.
    Luke V8's Avatar
    Luke V8 is offline AKA Luke!
    VE Commodore SSV
    Feb 2011
    I use a DAS-6 Pro from Car Care Products - it's great. For a non-abrasive polish (just for shine, not correction) , i usually polish apply by hand (CG Black Light) and then use a microfibre bonnet over the pad to remove it. Once a couple of layers are applied i then apply wax by hand and remove by hand (Petes 53 Black Pear Wax)..
    Thats just for some added shine..
    If i'm correcting the paint then the DAS-6Pro is used to apply the abrasive polish..
  1. Washing Machines
    By Jesterarts in forum The Pub
    Last Post: 18-09-2011, 01:02 PM
  2. Abdominal Machines
    By Deutscher in forum The Pub
    Last Post: 29-12-2009, 09:35 PM
  3. advice for first timer buffing my car
    By andyos in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-06-2009, 06:53 PM
  4. Buffing out scratches etc.?
    By Cobra Clutch in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-05-2009, 02:34 AM
  5. Buffing out scratches etc.?
    By Cobra Clutch in forum General
    Last Post: 03-05-2009, 02:40 PM
