i have alot of superficial scratches allover my car.. i cut and polish it maybe once a month and that doesnt work.. ive tried cutting compound buy it scratches the sh1t out of it even more.. is there anything i can use to get them out? thanks
Can use a meguiars product called scratch-x it could be the fault of the sponge/cloths you are using.
i use the applicater pad that comes with the cut and polish and a cut up towel to wipe off. so that might not be helping. what is that stuff mate? is it a rub on, rub off like cut and polish? where would i get it from? thanks mate
Best to do a machine polish and correct the paint, not use something that contains "fillers" and masks the problem temporarily.
You will only have to do it once, and otherwise you just have to seal with a synthetic sealant or wax and maintain by washing itAre you already using the two-bucket method, microfibre or lambswool wash mitt? And please, NO chamois! :P
Car Care Products Australia
www.carcareproducts.com.au - 1300 006 007 - info@carcareproducts.com.au
Do you care for your car?
For Special Promotions, Exclusive Deals and the Latest New Products follow us on Facebook
i wash it with turtle wax car wash, with a sponge and then chamois dry.... then ill hit it with polyglaze cut and polish with the included applicater pad and wipe that off with a cotton towel... looks good for maybe a day after doing it but then see all the scratches again...
by machine polish and correct the paint, do you mean with a buffer with liquid cut and polish or something else?
Without being the ball buster here.. which seems like i will. The way you are washing currently (Technique/products) is in fact what is causing those spiderweb style wash marks on the paintwork.
Example below is what they classify swirl/wash marks/spider webs on paintwork
As you can see with this picture below, 50/50 shot of half corrected and other needing to be corrected
Ideally its best to use a machine to correct this paintwork and you will only have to do this annually, bi-annually or a few years later again if you wash/maintain the paintwork correctly during the time.
The best way is a Microfibre Wash Mitt or Genuine Lambswool Wash Mitt for washing and for drying a Microfibre Waffle Weave Drying Towel or a Microfibre Chamois (not PVA or Leather!). The reason for this is that to ensure you do not take any dirt that has been missed or dust particles and drag them over the paints surface. So for example a sponge will grab the dirt and drag it along the surface, where a Mitt itself will hold the dirt inside the fibres itself and not drag over the paint.
Same goes for the waffle weave drying towel, any dirt that you have missed will sit in the centre of the waffle itself and not on the paint surface.
2 buckets method here shows 1 bucket for soap and 1 bucket for clean water. wash/rinse, wash/rinse to avoid any chances of dragging dirt back to the paintwork.
Make sure you use a decent pH Neutral Wash Shampoo otherwise you will just remove any wax/sealant thats over your cars paint as well. Can be any, provided its pH Neutral!
And yes machine correction. The reason this is by hand you will have almost nil result as you do not have the speed, consistency and effort vs a machine unfortunately![]()
awesome.. ill definatly be getting the wash and dry mitts.. and as for cut and polishing/polishing the car with a buffer, what is the best stuff for me to use? i have armor all liquid cut and polish at the moment waiting to do it but if there is something better i can use, i will to ensure a good job done. thank you
jason,
if you want to get it all done in one hit i would suggest a DAS6 Kit with Menzerna Polishes to correct your paint. You can finish off with a nice wax or synthetic sealant .. thats up to you!
So in order
Wash car
Clay Bar car to remove contaminants
Correct paint with machine work
wash car again to remove oils/polish from car which is left over that you may of missed.
Finish off with a nice wax like dodo juice or synthetic sealant like duragloss 111
finished!1 day work of pain to glory!
whats clar bar car mean? sorry if thats a dumb question..
Jason,
not a dumb question at all mate! never ask, you never learn!
Jump here in the How-To Section and have a read over and watch the videos. This should give you bit more of an idea of the process and other things for your car care/detailing.
Let me know how you go/if you have more questions we can continue through it all.
thank you very much for all the advice.. i cant wait to get all these products and hit the vt.. its look clean as haha.. thanks again mate..
All good dude!
Let me know if you get stuck or need any help or if you aren't sure what you need exactly in the kit just email or pm or post up and we can sort it out for you to work out what you do and dont need to stop you from getting carried away!![]()
checked out the link, read the instructions and watched the videos. very detailed and they make the surface look extremely nice and shiny. i will be doing this to mine as soon as i find the correct stuff. thank you once again..
any chance at all you could give me a list of what i would need to give my car a good once over? thank you
Jason,
Shoot me an email to info@carcareproducts.com.au and ill shoot a list across to you
no worries ill send one now.. cheers
once you use a polisher like the das6 to polish a car you will never do it by hand again, ill garentee that
Woah, great info in this thread!!!!
Thanks very muchI didnt know id been doing it wrong all this time, i suppose for the daily bus ive been a bit blaze'
Thanks again CCP - ill have to look into ordering some stuff of you in the future!
