We have a complete range of exhaust systems to suit the entire range of holdens
starting with our own design extractors to suit the v8's in the VT-VE range, avaliable in 1 3/4 and 1 7/8 primary sizes, they are a 4-1 design with nice 3in merge collector
the v6 range is also covered with pacemakers,
cat backs we have a full range starting at dual 2.25 in for the v6's up to dual 3in for the v8's, all are avaliable in mild steel or stainless steel and varex rear mufflers are avaliable for all models, we can mix and match parts together to give you a system that will suit your needs and budgets, IE if you had a VY sedan and wanted a mild steel 3in but wanted a varex muffler then we can use the mild centre section and the stainless varex rear,
i will get a full range of pics up shortly
Hey mate got any pics and prices of the dual 2.25" catback for a VS V6? Does this mean they suit a twin cat setup? Cheers
Hi mate,
I have a VZ SV6 and im looking for a dual 2.25" into single 3" cat back exhaust, how much would that set me back?
give us a call on 96802777 for pricing, we have to custom make the front half to suit the twin cat setups on the early models but this is no problem,
OK thanks for that. BTW its a 2005 VZ if that helps.
go to your local exhaust shop and get them to fit a sports system for that model, most will have them on the shelf for under $400
does anyone know how much it would cost for redback extractors? as the exhaust is redback.
what you got for vl's ?
redback/genie extractors would be around the $1000 mark fitted to the car etc..
Vl's we usually custom make the system depending on what the owner wants, anything from single 2.5in to single 4in depending on power levels etc
Is a twin 3" system too large for a stock genIII?
Hey , just wanted to thank the boys for today ... Had xforce headers installed on my Vz sv6 and hi flow cats pushed back to suit and fit ,good job and very happy ... Will be coming back for a tune very soon ... Thanks again !!!
