Hi Guys,
we are fully equiped to dyno tune all makes and models,
these include the VT-VE range of Gen 3 and Gen 4 V8 powered cars,
also include the VZ-VE range of V6 cars including all SIDI engines, we were the first to develop the V6 tuning soultions and the first to offer custom tuning on the SIDI engines and are still the only people in Australia to offer custom dyno tuning where we can remap your car.
we have the latest Dyno Dynamics dyno housed in a sound proof cell with enough extraction fan to support cars with over 1000hp and still retain fresh air
we are also Haltech Premium dealers and can supply and fit the entire range of Haltech ecu's including the Sport GM plug and play Delco replacment ecu..
You use LS1 ecu's for tuning the 5L how much does this cost drive in drive out?
we have a few options for the 5L's, if they are manual we use the Sport GM haltech ecu, auto we use the LS1,
the Haltech is $1895 drive in drive out,
the LS1 is around $2200 drive in drive out,
Dale
Hi, how much for a halltech ecu for a VS 6 cyl ? shipped to melbourne if possible, thanks
Haltech sport GM will only work on Manual VS, so it if it manual $1495
if it is auto you will need to wire in a sprint 500 which is $1100 or a sport 1000 which is $1795
Yeh its a VS Manual, mafless tune and other work done to it
It runs super rich on the tune from the stock ecu, what benefits will installing this haltech ecu give me ?
Manual VS T5 : http://forums.justcommodores.com.au/...manual-v6.html
the main advantage is any one can tune them. they generally tune up and cold start better than the factory ECU, IMHO the haltech controls the factory idle motor better than the factory ecu
Dale
Ok so being a 5 speed manual how much is the final price to post to melbourne and will it plug straight in from the old loom or does it require modifications ?
no mods, direct plug and play, comes supplied with base maps to run a stock 6 or 8cyl engine,
$1495 posted
ok well mines far from stock .. stage 3 cam etc but il be purchasing this when a job comes my way, thanks bud, can you pm me payment details if thats ok ?
How much to Tune my vn v6 s1. It has a stage 2 cam. double row timing chain. Extractors. 2.5 inch exhaust. pod filter. S2 intake manifold and coil pack. Engine cylinders bored +40 thou and crank ground down +40 thou. I was told by crow cams that I would not need a stand alone chip and my stock computer could be tuned.
If someone is to tune their car there, and then go elsewhere, they should be allowed right? I mean, it is their car...
My Black Pontiac G8 GT
My Front Bar & Bonnet For Sale
Saving for my twin turbo kit.
hope you can help, im in n.z. and have a 5.0 vt calais auto.
how can i turn off the torque management???
however invented it should be shot.
only way on that is to get a new memcal written
How much do you guys quote for a dyno?
for what model car?
how much for an OTR and Mafless-tune on an SS 5.7L? drive in drive out?
$1250 mate
$880 tune or $1350 intake and tune
How much for a tune on a 2007 VE SV6 with a 2.25' Cat Back
Also what power gains would you expect
VE SV6
2.25' Xforce Cat-back
Advanti Madrid 20x8.5
$880 tune and $1495 with intake..
normal gains with the stock air box is 12-15rwkw, 15-20 with the air box
Hey how much for a tune on a 05 vz sv6 auto ? Also can you fit xforce headers if supplied, if so how much for that too ?
as above $880 or $1495,
$200 to fit headers
can you remove the torque limiter off a vz v6 auto if so how much
