Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: diff gears in relation to dyno output result
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Default diff gears in relation to dyno output result
    hi all. i remember seeing a dyno reading once where the torque curve was something spastic like 755NM, but the HP curved topped out at 200 is HP. some members said it was the result of the car being tested in 3rd gear instead of 4th and was wondering if final drive would have an effect on the figure read off a dyno.
    discuss:
    ari666's Avatar
    1966 impala
    Mar 2009
    VT spac super6
    Nov 2008
    Riverton sa
    Lower the gear = more torque
    basic principle, hp= torque/time
    torque gets you moving, hp keeps you there
    if that makes sense
    faster it spins, less torque
    Shoes
    Aug 2009
    The Racetrack
    my physics knowledge is limited but i'll give it a go.
    horsepower is calculated like this.
    hp=(torque x rpm)/5252.
    gear choice for a dyno run has a huge effect on the torque reading that is given, because of how how the ratio acts as a torque multiplier. as does wheel size. so does the diff ratio. so does a torque converter.
    so when you're getting a torque reading at the wheels, its showing the force that is acting on the dyno rollers themselves, not the force that the engine is emitting. its usually called tractive force.
    i think you can calculate engine torque on a chassis dyno, but its super hard. heaps of ratios and stuff like bearing drag etc.
    ps. im sure i could answer it better but its bed time.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Quote Originally Posted by NonStick Squid View Post
    @old mate you drive a vs ute therefore you're a bogan therefore your point is invalid
    ari666's Avatar
    1966 impala
    Mar 2009
    ok, so if the dyno guy didnt ask me what my diff gears were and entered in 3.08 instead of 3.55 would this mean my HP would increase or decrease?
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    im not sure your horsepower would change, as horsepower is defined as the "rate at which work is done" and torque is related to the turning force of the crank, or something along the lines of the amount of "work" that is available to be accelerated by the "horsepower". if my memory serves me, i could be wrong. stranger things have happened.
    Shoes
    Aug 2009
    The Racetrack
    i don't reckon the horsepower would be any different, but there would be more torque.
    VN Calais 5L
    Dec 2006
    how can the horsepower be the same with the torque reading being different? a car with lower ratio diff gears is gunna give a higher hp reading off the dyno than the same car with standard diff ratios. if i understand the way a dyno works properly.
    in theory, if the fact he put in 3.08 diff ratios instead of 3.55 does make a difference, then you would have got a higher reading than if he put in 3.55 instead of 3.08
    thats the way i look at it anyways. im sure if im wrong, someone clever will come and correct me.
    VY Commodore Ute
    Dec 2009
    North Adelaide,SA (uni) / Mildura, VIC (home)
    From my Mechanical Engineering knowledge, Power (KW or HP) is power the engine can create and is usualy constant. Changing dif gears would increase torque but lower the maximum RPM that can be acheive thus the overall power of Engine (Torque*RPM) is still constant. So would have no effect on final maximum HP/KW.
    I dont have any Direct experience with Dyno's and testing though so whether this translates to real world experimental data as there are other factors to consider that effect power output such as friction losses etc that vary with RPM. Need a dyno guy to give us the answer to this one. But i would expect it to be a small variation.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Ahhhhh.....the old "pretend" HP/kW figure.
    A dyno measures torque, nothing else. It can't even tell what RPM the engine is doing without some input from the user. The dyno then uses the input data to give a torque reading. It then calculates the "power" figure from that using a formula.
    By changing diff gears you are changing torque so the "power" figure has to change. But then it also depends on where that peak torque is achieved in the rev range and that will have an effect on the end result as well.
    Example, say you pulled 300ft lb of torque at 5000rpm, that calculates to 285hp, but if you went a bit shorter in your diff gears and got 332ft lb of torque at 4500rpm, it still equates to 285hp. But....say it pulled the same 300ft lb at 4500, you would get a drop down to 257hp, even though you haven't done anything to the engine.
    Visit my Facebook page
    ari666's Avatar
    1966 impala
    Mar 2009
    ok, so from old mates calculation,
    197.8= ( A x 5900) 5252
    A= 176.075 flbs @ 5900rpm? seems pretty damn low... 238 NM ... weird since a stock VK black is supposed to produce 361@2800rpm.
    but wait.. for that calculation to work, i would need to know peak rpm for torque???? i only know peak rpm for KW. how does that work?>???
    ari666's Avatar
    1966 impala
    Mar 2009
    ok, now i am full of question marks.
    how can it be, that if torque is the ONLY figure really being calculated, HP will quite often go up the rev range quite a lot further. random internet example pics:
    a lot of the dyno sheets i have looked at, the torque is completely unrelated to the HP curve. torque generally peaks early and peters off, whereas HP keeps climbing.
    ari666's Avatar
    1966 impala
    Mar 2009
    HRT 666's Avatar
    HRT 666 is offline Cammed 8t-body stroker
    VX R8 Clubby S2 M6
    Dec 2006
    S.A.
    Thats because HP = torque X rpm so even if the torque starts to drop off slightly but the rpms continue to climb the HP will continue to climb also.
    Only if the torque drops off at a large rate as the rpms climbs then the HP will feather off.
    Make sence now?
    The torque curve will never be UNRELATED to the HP curve as without torque and rpm you will have NO HP.
  15. #15
    ari666's Avatar
    1966 impala
    Mar 2009
    that makes no sense at all.
    so then given my calulation (if i have done it correctly) you saying that somehow i have managed to make the power (KW) increase dramatically over stock, but make the torque decrease ASTRONOMICALLY
    ill drop the stats again for those that cbf reading
    147.5 RWKW
    197.8 HP
    176.075 ftlbs torque
  16. #16
    HRT 666's Avatar
    VX R8 Clubby S2 M6
    Dec 2006
    S.A.
    No that is NOT what I said. For you to end up with any increase in power you will HAVE to have an increase in torque at the same rpm as before.
    As it just wont happen with out the torque (unless you kept the same torque and doubled the rpm) and that would not of happened.
    Put up the before and after dyno sheets.
  17. #17
    Shoes
    Aug 2009
    The Racetrack
    HRT's got it. look at this for an example, using the EVO X dyno sheet.
    3650 rpm there is near on 320 lb/ft.
    (3650 x 320)/5252 = 222.3914 hp
    but later on when the torque tapers back to about the same level as before, but at higher rpm it works like this:
    5600 rpm and close to 320lb/ft.
    (5600 x 320)/5252 = 341.2034 hp.
    so the only reason the power figure has gone up is because the torque figure is made at a higher rpm.
  18. #18
    VT
    Apr 2005
    QLD
    Go to the drag strip.
    If it pulls the wheels after a warmup, its got enough torque
  19. #19
    Shoes
    Aug 2009
    The Racetrack
    ok ari666, i just checked out your dyno sheet. lets do some calculations here to work out whats going on.
    its pretty blurry so my numbers wont be 100% spot on. so bear with me.
    first lets pic some spots in the rpm range. i might as well do every 200 rpm and then make a graph in microsoft excel. would help my statistics study haha.
    im converting from kw to hp at 1.341hp per kw.
    2800 = 85.854hp (64kw)
    3000 = 100.575hp (75kw)
    3200 = 109.962hp (82kw)
    3400 = 120.69hp (90kw)
    3600 = 135.441hp (101kw)
    3800 = 147.510hp(110kw)
    4000 = 156.897hp (117kw)
    4200 = 162.261hp (121kw)
    4400 = 171.648hp (128kw)
    4600 = 174.330hp (130kw)
    4800 = 182.376hp (136kw)
    5000 = 187.740hp (140kw)
    5200 = 190.422hp (142kw)
    5400 = 189.082hp (141kw)
    5600 = 191.763hp (143kw)
    5800 = 197.127hp (147kw)
    5900 = 197.7975hp (147.5 kw)
    alright, so we have all the hp figures and rpms for every 200rpm from 2800 to 5900.
    if we apply the formula “torque = (5252 x HP) / rpm” to each of these we can work out the torque at each spot. here goes.
    Im converting ft/lb to nm by multiplying by 1.356
    2800 = 85.854hp (64kw) 161.0376 ft/lb 218.3670 nm
    3000 = 100.575hp (75kw) 176.0733 ft/lb 238.7554 nm
    3200 = 109.962hp (82kw) 180.4751 ft/lb 244.7243 nm
    3400 = 120.69hp (90kw) 186.4306 ft/lb 252.7998 nm
    3600 = 135.441hp (101kw) 197.5934 ft/lb 267.9366 nm
    3800 = 147.510hp (110kw) 203.8743 ft/lb 276.4536 nm
    4000 = 156.897hp (117kw) 206.0058 ft/lb 279.3438 nm
    4200 = 162.261hp (121kw) 202.9035 ft/lb 275.1372 nm
    4400 = 171.648hp (128kw) 204.8853 ft/lb 277.8245 nm
    4600 = 174.330hp (130kw) 199.0394 ft/lb 269.8974 nm
    4800 = 182.376hp (136kw) 199.5497 ft/lb 270.5894 nm
    5000 = 187.740hp (140kw) 197.2021 ft/lb 267.4060 nm
    5200 = 190.422hp (142kw) 192.3262 ft/lb 260.7944 nm
    5400 = 189.082hp (141kw) 183.8898 ft/lb 249.3681 nm
    5600 = 191.763hp (143kw) 179.8463 ft/lb 243.8716 nm
    5800 = 197.127hp (147kw) 178.5019 ft/lb 242.0486 nm
    5900 = 197.7975hp (147.5 kw) 176.0733 ft/lb 238.7554 nm
    ok so now we have all the data as an estimate of your rear wheel output. i might make some pretty graphs in a sec for it. i must say though, your engine doesn't have heaps of torque.
    Attached Images Attached Images
  20. #20
    ari666's Avatar
    1966 impala
    Mar 2009
    I have never been so thankful till right now. thats brilliant, thanks mate. really appreciated.
    yep. my engine is shit.
  21. #21
    Shoes
    Aug 2009
    The Racetrack
    haha no worries, i was bored and was a good excuse to mess around. it wont be 100% accurate but it does give a good indication of the shape and size of the curves.
    it must feel pretty linear to drive i reckon.
  22. #22
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by old mate View Post
    the weird thing is that its one of the most stupidly happy cars i have ever driven. i dunno how to explain it. even if the graph says its weak, there have been times i would swear that graph is way off.
    but yeah, you answered the question above and beyond what id hoped for so rep your way.
  23. #23
    VR
    Jul 2010
    sydney
    Default diff gears
    hey guys i dont know if this is an old post but in relation to diff gears ive had first hand experience and i work as a mechanic they dont increase your torque or your horsepower what happens is basicly you have a smaller ratio so you take off harder only letting your torque kick in earlier so running down the quarter would be great
    so say if a car has 200 horsepower and 150nm (nm is newton meters) torque e.g like how tight you do up a wheel nut 90nm if you ran your car on a dyno on the standard set of diff gears say the car on those gears has a max speed of 200kmh
    a smaller set of diff gears whitch is good for your drag racing you use the same power same torque but just the car always seems to have torque becouse it doesent require as much to push the car forward on a smaller set of gears
    a tall set of gears will help your top speed but they end up being harder to turn and etc
    if you look at a dyno sheet with a torque curve reading
    1) standard set of diff gears you might say see a say 45 degree diagonal line
    2) short set of diff gears you will see the line shoot straight up say a 70 degree line all it is is the power coming on all in one go rather then gradually
    3) tall set of diff gears you will see a long line say a 30 degree line
    but its a curve not a perfectly straight line
    thats what i know dont bag me out just trying to help if you dont understand ask me and i will try and explain it better
  24. #24
    bauer5152
    Jul 2011
    bauer5152
    Quote Originally Posted by Brados View Post
    I also think so.
  25. #25
    ari666's Avatar
    1966 impala
    Mar 2009
    here is an interesting fact. the torque curve and HP curve should always intersect at 5252rpm or the dyno reading is false
    true story bro.
  1. [SA] WTB- 3.89 diff gears to suit borg warner diff
    By GTP 85 in forum Swap / Wanted to Buy / Trade
    Last Post: 31-05-2010, 01:23 AM
  2. !change of top speed in gears when fitting 3.7 diff gears.!!??
    By slappedvr in forum V6 Development And Modification
    Last Post: 30-01-2010, 09:54 PM
  3. changing diff gears or full diff replace?
    By callum_88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-05-2009, 06:59 PM
  4. dyno result vy v6 170.4HP is it good or?????
    By imartinoski in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-01-2009, 10:37 PM
  5. poor dyno result
    By johnvtls1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2008, 01:28 PM
