Page 2 of 15 FirstFirst 12345612 ... LastLast
Results 26 to 50 of 357
Like Tree32Likes
Thread: Dyno Sheets
  1. #26
    EvoVIIIJDM is offline Got Evo?
    Evo VIII JDM
    Nov 2005
    LS1Chub / Luke/ VX Clubby
    (241rwkw)
    Engine Type and Capacity:LS1 5.7
    Power Adders: OTR and Tune
    Trans Type (M6, A4, etc): A4
    Diff Ratio: Stock
    Wheel/Tyre size:R18
    Fuel Type: 98RON
    Name Of Workshop: Willall Racing/ LS1 Turbo
    Date Dynoed: Couple weeks ago
    __________________
  2. #27
    vq
    Oct 2007
    tanka5.7/damo/vq statesman
    HP (XXX.Xhp), kW (145.4kW)
    Engine Type and Capacity: 304 v8
    Power Adders: reversed ls1 maf pipe with k&n pod and 2 1/2 inch exhaust with high flow cat
    Trans Type : full manual t700
    Diff Ratio:3.45
    Wheel/Tyre size: 205/65-15 at the time
    Fuel Type: 98 ron
    Name Of Workshop: castle hill exhaust
    Date Dynoed: 5/3/08
  3. #28
    Cursed CX8 is offline Banned
    VY Adventra
    Feb 2008
    Walking distance to FG meets
    pulling off the pod might give you better power reading. A CAI and K&N will stop the engine pulling hot air from the engine bay, and will still allow great flow
  4. #29
    vq
    Oct 2007
    the bonnet was up, so that wouldnt have effected it. im happy with anyway it has nearly 220,000 on it and has never been opened. its makes alot more than the stock 165fwkw
  5. #30
    VY Adventra
    Feb 2008
    good point on the bonnet being up. but what about road driving, its going to heat up under there.
  6. #31
    vq
    Oct 2007
    Quote Originally Posted by Classifi3d Calais View Post
    yeah mate im not to fussed bout it, im not a street racer, i just take the passenger side headlight out at the track and it works great, ill be goin a carby style manifold soon enough anyway.
  7. #32
    VR V6 Turbo
    Apr 2008
    300kwv6 / Josh / VR V6
    HP (391.1hp), kW (291.7kW)
    Engine Type and Capacity: 4.3L V6
    Power Adders: Garrett GT35R
    Diff Ratio: 3.08
    Wheel/Tyre size: 205x65x15
    Fuel Type: BP Ultimate 98
    Name Of Workshop: Sanmateo Performance Systems - Dyno Day
    Date Dynoed: 06/11/10
  8. #33
    MaN|aC's Avatar
    MaN|aC is offline Donating Member
    VT 4.2 S/C
    Apr 2006
    MaN|aC / Allan / VT ecotec
    HP (268.6hp), kW (200.5kW)
    Engine Type and Capacity: 4.2 litre L36
    Power Adders: COME stroker, Raptor supercharger, mafless tune
    Diff Ratio: 3.45
    Wheel/Tyre size: 245/35R19
    Name Of Workshop: Chip Torque
    Date Dynoed: 17/4/08
    incredible torque from a 6
    208rwkw 13.5 @ 102MPH
    STROKED AND BLOWN
  9. #34
    VN HSV WAGON
    Jan 2008
    PINKY355 / Ian Pinker / 1990 SV Wagon
    HP (332rwhp), kW (248rwkW)
    Engine Type and Capacity: Holden 355ci balanced, honed, blue printed blah blah, ARP stud kit, race bearings, HV oil pump, High energy sump etc
    Power Adders: COME crank and TTB manifold. 286 cam. Big v/v heads with 1.65 r/rockers. Flat top Hyperuetectic pistons, 10-1 comp. Pacemaker tri-Y headers into hiflo 3" cat and system
    Trans Type (M6, A4, etc): Toughened T700 A4
    Diff Ratio: 3.73 lsd
    Wheel/Tyre size: 235/40/18
    Fuel Type: BP ultimate
    Name Of Workshop: Kwinana performance
    Date Dynoed: 4/4/2008
    Dyno sheet can be veiwed on my car thread. Cant seem to get it to work here
    Last edited by PINKY355; 30-06-2008 at 10:48 AM. Reason: couldnt get the dyno sheet attachment to work.
  10. #35
    VZ Clubsport R8 M6/LS2
    Jan 2005
    NSW
    IEVLV8 / Ross / VZ Clubsport R8
    kW (228.1rwkW)
    Engine Type and Capacity: LS2 6.0Ltr
    Power Adders: NONE
    Trans Type (M6, A4, etc): M6
    Diff Ratio: Standard
    Wheel/Tyre size: standard
    Fuel Type: PULP
    Name Of Workshop: BTA Motorsport
    Date Dynoed: 20/10/1007 date was out coz didn't have car then Sept 07 sometime
  11. #36
    VL GPA HDT Brock
    May 2008
    5.0L VS Ute is offline 355 Vh
    355 5.8L Vh
    Nov 2007
    355 Vh / Sam/ VH SL
    HP - ??? kW (200.9 rwkw)
    Engine Type and Capacity: 355 Stroker V8
    Power Adders: stroked to 355ci by C.O.M.E, Keith Black Pistons, 650 dp holley, holley blue electric fuel pump, larger fuel lines, 2500 stall, turbo 350 trans with stage 3 shift kit, (soon to be installed B & M Quicksilver Shifter), VL Turbo diff (LSD), VL Turbo Brakes, 3" exhaust with genie extractors,
    Trans Type: (turbo 350 trans, stage 3 shift kit)
    Diff Ratio: VL Turbo Diff with LSD (3:45 Gears)
    Wheel/Tyre size: 15" Interceptor rims (Cop Rims - Deep Dish ones), 225's
    Fuel Type: unleaded
    Name Of Workshop: Morpowa, Modbury
    Date Dynoed: 26-5-2008
    Attached Images Attached Images
  13. #38
    KiWi1's Avatar
    KiWi1 is offline 11.00@126 Miss dat ****
    Dead 11sec VX SS, Defected VP Ute
    May 2008
    HIGGINS RACE DEVELOPMENTS
    KiWi ™/ Simon / VP Ute
    HP (157.9rwhp), kW (117.8rwkW)
    Engine Type and Capacity: SeriesII Buick 3.8L
    Power Adders: exhaust, airbox
    Diff Ratio: 3.08
    Fuel Type: Unleaded
    Name Of Workshop: Backyarder job
    Date Dynoed: 03/07/2007
  14. #39
    winton's Avatar
    winton is offline black+manual+19's=sex
    vs SS II 5speed vx gts 19's
    Apr 2007
    modbury
    winton/ daniel/ vs SS II
    HP (210hp), kW (156.6kW) (If you only know one, ill work it out for you)
    Engine Type and Capacity: 5L
    Power Adders:185i extractors, 2.5inch single exhaust. stage 3 cam Trans Type (M6, A4, etc): 5speed m5
    Diff Ratio: 3.08 stock
    Wheel/Tyre size: 19'' gts
    Fuel Type: bp ultimute
    Name Of Workshop: morpowa modbury
    Date Dynoed: 28-5-08
    new car: 96 vs SS II BLACK+5 SPEED
    http://forums.justcommodores.com.au/...ad.php?t=57053
    ^^^cheak it out^^^
  15. #40
    winton's Avatar
    Apr 2007
    modbury
    winton/ daniel/ vr exec
    HP (hp), kW (111.9kW) (If you only know one, ill work it out for you)
    Engine Type and Capacity: 3.8L buik
    Power Adders:CAI catback 2.5 exhaust
    Wheel/Tyre size: 17'' roh furys
    Name Of Workshop: ultratune salsibury
    Date Dynoed: 16-12-07
    ^^^cheak it out^^^
  16. #41
    VXSS II
    Jun 2008
    ChargedBT1 / Jackson / VS BT1
    HP (316rwhp), kW (236.rwkw)
    Engine Type and Capacity: 5.0
    Power Adders: Vortech V2 Supercharger
    Trans Type 4 Speed Auto
    Diff Ratio: 3.08
    Wheel/Tyre size: 17" 235 45 17's
    Fuel Type: Premium
    Name Of Workshop: Port Adelaide Auto Repairs
    Date Dynoed: 20 May 08
  17. #42
    Enhanced Auto cammed VXSS 5.7A4
    Jul 2005
    Greenwith S.A
    evlss1 / Jason / VX SS
    HP (385.4hp), kW (287.4kW)
    Engine Type and Capacity: 5.7lt LS1
    Power Adders: cam,zorst,t/b,otrcai custom tune
    Trans Type (M6, A4, etc): built & stalled 4l65e A4
    Diff Ratio: 3.07
    Wheel/Tyre size: 235/45/17
    Fuel Type: ultimate
    Name Of Workshop: Enhanced Automotive
    Date Dynoed: Aug 07
    i proudly use and recommend
    Enhanced Automotive - 1/11 Bremen Drive
    Salisbury South - 8250 2233
    Pushing The Limits In The Performance Industry
  18. #43
    HRT 666's Avatar
    HRT 666 is offline Cammed 8t-body stroker
    VX R8 Clubby S2 M6
    Dec 2006
    S.A.
    Have you had your car on the new mainline dyno jason? would like to see the results from that.
  19. #44
    Vn Calais 5ltr, Vg ute,
    Jun 2008
    ^^ would b interesting..seems they deff read different..( i still think main lines are the honest one..LOL) gotta get mine on one too
  20. #45
    nicko451's Avatar
    nicko451 is offline Nicko
    VY Executive V6 5Spd
    Sep 2005
    Nicko451 / Chris / VY V6
    HP (165.1hp), kW (XXX.XkW)
    Engine Type and Capacity: 3.8 Ecotec
    Power Adders: Pace maker headers & 2.5"
    Trans Type (M6, A4, etc): M5
    Diff Ratio: 3.07
    Wheel/Tyre size: 16/50/225
    Fuel Type: Premium
    Name Of Workshop: Independant Motorsport Morwell
    Date Dynoed: 4-6-08
  21. #46
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS v6 track car & VS SSenator
    Aug 2006
    Murray Bridge S.A
    *Updated*
    REV-231 / Gilbert / VS v6
    HP (240), kW (179)
    Engine Type and Capacity: Ecotec V6 3.8L
    Power Adders: cam,zorst,springs,otrcai, custom dyno tune, and more...
    Trans Type (M6, A4, etc): T5 manual
    Diff Ratio: 3.45
    Fuel Type: Regular shell
    Name Of Workshop: Awesome Automotive
    Date Dynoed: 18th July 08
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.03 @ 103 Mph... A 12 is but a run away! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily Senator rep: http://forums.justcommodores.com.au/...ite-vr-ss.html
  22. #47
    VZ SS 6 SPEED MANUAL
    Apr 2007
    WA
    Quote Originally Posted by REV-231 View Post
    *Updated*
    HP (240), kW (179)
    Diff Ratio: 3.45
    Hey Mate
    Nice figures for a NA V6, have you taken it down the Quater mile yet ??
    Or got any 0-100 figures, curious to see what times you get ??
    Thanks Mate
  23. #48
    nicko451's Avatar
    Sep 2005
  24. #49
    HRT 666's Avatar
    VX R8 Clubby S2 M6
    Dec 2006
    S.A.
    HRT666/Steve/VX S2 Clubsport R8
    384 HP or 286.6 rwkws
    Ls1-346
    Cam+bolt ons
    T56, z grip clutch, rip shift
    3.73 lsd
    20"rims with 245 tyres
    Bp 98
    Work done by ENHANCED AUTOMOTIVE
    Dyno date 20-7-08
  25. #50
    E92 BWM 335I
    Sep 2007
    Melton,Victoria
    john/ VT SS
    (214rwkw)
    Power Adders: OTR, Tune, Exhaust
    Diff Ratio: Stock
    Wheel/Tyre size:19"
    Name Of Workshop: GM Motorsport
    Date Dynoed: last week some time
  1. Build sheets under carpet
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-03-2013, 05:01 AM
  2. Dyno Sheets
    By kilmo in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-05-2007, 10:36 AM
  3. Really need your help to find gasket sheets
    By craigvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-11-2006, 09:45 AM
  4. What do you think i got on the dyno
    By Stewart1000 in forum General
    Last Post: 23-10-2006, 01:29 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
