Page 3 of 12 FirstFirst 1234567 ... LastLast
Results 51 to 75 of 279
Like Tree6Likes
Thread: Dyno Sheets
  1. #51
    Sphinx's Avatar
    Sphinx is offline O.G.
    VX Calais II LS1
    Aug 2005
    Pakky
    Default DCE1VE's dyno run
    Sphinx / Mike / LS1 VX Calais
    HP (358hp), kW (263.4kW)
    Engine Type and Capacity: LS1
    Power Adders: MAFless tune,Ziggy OTR, Crow 223/223 cam, FAST 92mm manifold, Nick Williams 92mm TB, FAST 36lb/hr injectors, 1 5/8 inch tri-y packemakers, high flow cats, dual 3 inch catback.
    Trans Type (M6, A4, etc): A4
    Diff Ratio: 3.08
    Wheel/Tyre size: 225/55/16
    Fuel Type: Ultimate 98
    Name Of Workshop: Chevs
    Date Dynoed: 29/1/2010
    The Calais
    Sleeper Club
  2. #52
    hsvpunk's Avatar
    hsvpunk is offline volunteer firefighter
    vy ss II M6
    Jan 2007
    Mornington, Vic
    nice mike. Any other good looking cars at Chevs???
    dont worry, il start a ride thread soon.
  3. #53
    Sphinx's Avatar
    VX Calais II LS1
    Aug 2005
    Pakky
    yeah a few cammed VE SS's that sounded bloody brilliant. starting to get 6 litre envy haha
    The Calais
    Sleeper Club
  4. #54
    LowVp's Avatar
    LowVp is offline VP nut
    VP Ute 3.8T M5
    Aug 2005
    Ipswich, Qld
    Update from page 1
    LowVp / Dru / 93 VP ute
    HP (XXXrwhp), kW (217.5rwkW) (If you only know one, ill work it out for you)
    Engine Type and Capacity: 3800
    Power Adders: Turbo and associated gear, stock internals
    Trans Type (M6, A4, etc): M5
    Diff Ratio: 3.45
    Wheel/Tyre size: 235/45/R17
    Fuel Type: 98 octane
    Name Of Workshop: Dyno Tunz
    Date Dynoed: 26/7/08
  5. #55
    VY S2 SS ute
    Jan 2008
    Conn / Con / VSII ute
    HP (XXX.Xhp), kW (130rwkws) (If you only know one, ill work it out for you)
    Engine Type and Capacity: ecotec
    Power Adders: CAI, filter, pacemaker extractors, lukey single muffler 2.5' exhaust, YT 1.95 roller rockers
    Diff Ratio: 3.08
    Wheel/Tyre size: 235/45/17
    Fuel Type: 98
    Name Of Workshop: ART
    Date Dynoed: 18/08/08
    Attached Images Attached Images
  6. #56
    VT
    Apr 2005
    QLD
    VT-565/Nick/'97 VT Sedan
    HP (1002hp), kW (747.19kW)
    Engine Type and Capacity: Big Block Chev - 565ci
    Power Adders: Haven't switched on the gas yet...
    Trans Type (M6, A4, etc): A2
    Diff Ratio: Always changing
    Wheel/Tyre size: 32 x 14.5 x 15
    Fuel Type: VP C14
    Name Of Workshop: Shafiroff Racing Enterprises
    Date Dynoed: 23/06/2008
    http://www.filedump.net/dumped/nickdyno21219710769.pdf
  7. #57
    vr executive
    Apr 2008
    Got_balls/brenton/ vr v6 commo
    HP (244rwhp), kW (183rwkW)
    Engine Type and Capacity: v6 3.8
    Power Adders: extractors, raptor sc running 7.5psi intercooled
    Trans Type : t5
    Diff Ratio: 3.45
    Wheel/Tyre size: 17
    Fuel Type: 98
    Name Of Workshop: cbb racing penrith
    Date Dynoed: 02/04/08
  8. #58
    KiWi1's Avatar
    KiWi1 is offline 11.00@126 Miss dat ****
    Dead 11sec VX SS, Defected VP Ute
    May 2008
    HIGGINS RACE DEVELOPMENTS
  9. #59
    FORCED's Avatar
    FORCED is offline Huh Did Sum 1 Say FORCED?
    VX SS
    Sep 2006
    Noarlunga/Seaford
    FORCED / Damo / VX SS
    HP (XXX.Xhp), kW (235.5kW) (If you only know one, ill work it out for you)
    Power Adders: Mafless Edit, OTR
    Trans Type (M6, A4, etc): M6
    Diff Ratio: 3.4:5
    Wheel/Tyre size: 225/30/20
    Fuel Type: Unleaded
    Name Of Workshop: Southern Hi-Tech Dyno Tune
    Date Dynoed: 28/8/08
  10. #60
    vhrb30/vxs11v6
    Aug 2006
    canberra
    bec22 / shane / vh rb30 n/a
    HP @160, kW 119.3kw
    Engine Type and Capacity:rb30 3L
    Power Adders: k/n panel filter extactors 2.5in zorst
    second hand motor no idea on internals cost 500 with box diff and spares
    Power removers: stuffed o2 sensor backyard tune cheap fuel
    Trans Type:mf5
    Diff Ratiotandard 3.08?
    Wheel/Tyre size: 16x6
    Fuel Type:moblie standard E10
    Name Of Workshop: autotech
    Date Dynoed: 13/9/08
    note:first run my tune, second run expert tune
  11. #61
    R32 GTR 360AWHP
    Feb 2004
    Palmyra, WA
    Ewok / Chris / 05' VZ SV6
    191.2rwhp, 143rwkW
    Engine Type and Capacity: 3.6L Alloytech
    Power Adders: None
    Trans Type (M6, A4, etc): 5spd Auto
    Diff Ratio: Stock
    Wheel/Tyre size: 17" x 235/45's
    Fuel Type: 98RON
    Name Of Workshop: In Tune Performance, Bibra Lake WA
    Date Dynoed: 3rd August 2008
    Me? I'm the guy who does his job ... you must be the other guy ...
  12. #62
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    ^^not bad^^ i'll post mine up when i get it tuned on friday.
    Chev badges are an instant fail
  13. #63
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
  14. #64
    impulsesv6's Avatar
    A quick Alloytec
    Dec 2006
  15. #65
    ashbox's Avatar
    VZ SS 6 Spd
    Apr 2007
    The Car
    Got it tuned early
    Ashbox / Ashley / VZ Sv6
    HP (191.9rwhp), kW (143.1rwkW)
    Engine Type and Capacity: XXXXX
    Power Adders: 2 hole mod and holley air filter
    Trans Type (M6, A4, etc): A5
    Diff Ratio: Stock 2.84's i think
    Wheel/Tyre size: 235/45/17's
    Fuel Type: Bp ulti
    Name Of Workshop: Morpowa
    Date Dynoed: today 24/9/08
    will go to the drags to confirm this when i'm in vic cos we don't have any here
    before
    after
  16. #66
    VYClubby's Avatar
    VYClubby is offline Proud Clubby Owner
    294rwkw Oztrack Tuned 220 cam
    Nov 2006
    Vyclubby / Matt / Vy II Clubsport
    HP (380rwhp), kW (283.6rwkw)
    Engine Type and Capacity: LS1 346
    Power Adders: Cam, 25%, OTR, Exhaust
    Diff Ratio: Stock 3.73:1
    Wheel/Tyre size: 235/45/19
    Fuel Type: Bp ultimate
    Name Of Workshop: SAS dyno. TUNED BY OZTRACK
    Date Dynoed: 19/9/08
  17. #67
    Ripcell's Avatar
    Ripcell is offline R8 FTW!!!
    324rwkw MY06 VZ R8 Maloo M6
    Apr 2006
    East Melbourne
    Ripcell / Luke / VXII SS
    HP (309.rwhp), kW (231.rwkW)
    Engine Type and Capacity: 5.7Ltr LS1
    Power Adders: OTRCAI and tune
    Diff Ratio: stock 3.45
    Fuel Type: Shell 91 RON
    Name Of Workshop: GM motorsport
    Date Dynoed: 24/9/2008
  18. #68
    VY SS UTE
    Oct 2008
    RICECOOKER/ KB / VY SS UTE
    244 RWKW
    Engine Type and Capacity:5.7
    Power Adders:
    DIFILLIPO 4 INTO 1'S
    HIGH FLOW CATS
    TWIN 2.5 EXHAUST
    MAFLESS TUNE
    KAAZ DIFF
    K N N AIR CHARGER KIT
    Trans Type M6
    Diff Ratio: 3.91
    Wheel/Tyre size:19 INCH
    Fuel Type:98
    Name Of Workshop:CASTLE HILL EXHAUST CENTER XXXXX
  19. #69
    VY SS UTE
    Oct 2008
    Quote Originally Posted by VYClubby View Post
    dude you might want to have those afrs looked at they should be smooth
  20. #70
    VYClubby's Avatar
    Nov 2006
    Quote Originally Posted by ricecooker View Post
    Get Dale (CHE) to show you your readout with AFR's, your sheet, above, doesn't show them. Post it up if he gives it to you.
    Also have a look at other sheets in this thread that actually have the AFR's and you will see they are all not smooth. As long as it is in a certain ratio it is fine.
    Mine sits at around 12.5. Which is considered nice and safe.
    My car has a bung (threaded hole before the cats) in the exhaust, that Oztrack fits a wideband sensor into as he tunes. This gives a much better reading of AFR's, as on a dyno they put a sensor in your tailpipe and the readings can vary alot.
  21. #71
    VY SS UTE
    Oct 2008
  22. #72
    VYClubby's Avatar
    Nov 2006
    here it is nice and smooth
    Like I said, they could be set up to display the graph differently, to keep people that care how flat the line is happy . Or I would say CHE put a bung in the exhaust and fitted the Wideband in before the cats, which would give a smoother reading, my graph was done with a probe in the tailpipe. They are different versions of the software as well.
    As I said have a look back through this thread at some of the other sheets that are done in the same software version as mine, and none are as flat as yours
    Have a read of this thread.
    http://www.ls1.com.au/forum/showthre...t=afr+readings
  23. #73
    R32 GTR 360AWHP
    Feb 2004
    Palmyra, WA
    Quote Originally Posted by ashbox View Post
    Got it tuned early
    Fuel Type: Bp ulti
    Ash, yours is stock aswel apart from the tune hey?
  24. #74
    Dec 2005
    Here is my dyno run, unknown internals
    Leaning out bigtime, need a high flow fuel pump =[
  25. #75
    adamc11 is offline Donating Member
    VY SS
    Feb 2008
    E. & W. Suburbs Melbourne
    adamc11 / Adam / VY SS S1
    HP (XXX.Xhp), kW (253.7kW)
    Engine Type and Capacity: LS1 5.7L
    Power Adders:
    - CSV Fibreglass OTR
    - Mangaflow hi-flow cats
    - Pacemaker Tri-y's
    - 2.5" Catback exhaust of some kind
    - Brad (Enhanced) Mail Order Tune
    - NGK TR6 Spark Plugs
    Trans Type: M6
    Diff Ratio: Stock
    Wheel/Tyre size: Stock
    Fuel Type: 98 Ron Caltex
    Name Of Workshop: Westernlink Automotive
    Date Dynoed: 24/10/2008
    Comments: Was a bit skeptical of this high figure, but the guys at Westernlink Automotive reckon their dyno is pretty accurate. I saw dyno result for cammed cars they did that pulled 280-285rwkw or so, and other non-cammed ones with zorst that were around 230-240 so it doesn't seem like too happy a dyno. They said my air/fuel ratio was near perfect, and they thought it was pretty damn good overall for a mail order tune. Many thanks to Brad at Enhanced.
LinkBacks (?)
  1. Build sheets under carpet
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2012, 07:34 PM
  2. Dyno Sheets
    By kilmo in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-05-2007, 11:36 AM
  3. Really need your help to find gasket sheets
    By craigvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-11-2006, 10:45 AM
  4. What do you think i got on the dyno
    By Stewart1000 in forum General
    Last Post: 23-10-2006, 02:29 AM
