| Dyno Figures Think your commodore has the goods? Why not post up a dyno result and find out. |
25-04-2007, 10:58 PM
<---------Aint it true!
Ride: 91' VN SS & 94' VR BT1
Dyno Sheets
Ok if everyone could follow the layout below aswell as attach a dyno sheet I will update the list.
Your forum name / Your real name / Car model
HP (XXX.Xhp), kW (XXX.XkW) (If you only know one, ill work it out for you)
Engine Type and Capacity: XXXXX
Power Adders: XXXXX
Trans Type (M6, A4, etc): XXXXX
Diff Ratio: XXXXX
Wheel/Tyre size: XXXXX
Fuel Type: XXXXX
Name Of Workshop: XXXXX
Date Dynoed: XXXXX
__________________
function > form
04-05-2007, 01:38 PM
Ride: VZ S Ute
Kilmo / Nick / VZ 'S' Ute
HP (180.4hp), kW (134.52kW)
Engine Type and Capacity: 3.6L V6 Alloytech
Power Adders: * Pacemaker Headers * 700 cfm Hi-Flow Metal Cats * 2 1/2" Exhuast System * SS Inductions "Growler" CAI Kit *
Trans Type (M6, A4, etc): M6
Diff Ratio: ????
Wheel/Tyre size: 18's
Fuel Type: Ultimate 98
Name Of Workshop: Pro Auto Performance, Canning Vale
Date Dynoed: 19/04/07
__________________
Mods: * Pacemaker Headers * 700 cfm Hi-Flow Metal Cats * 2 1/2" Exhuast System * SS Inductions "Growler" CAI Kit *
To Come: * CAPA S/C Kit * VCMSuite Tune *
04-05-2007, 02:33 PM
Ride: VY Commodore/V8 Nissan Patrol
Dyno.
VY CHRISSO / Chris / VY Exec
KW (132rwkw)
Engine = 3.8 Ecotec
Power Adders: Pacemaker Headers, Twin Stainless Cats, Twin 2.5" mandrel System, Yella Terra 1.95 roller Rockers, Pod Filter, Piggy back ECU Shift Kit.
trans = A4
Diff = standard
Wheel / Tyres = 235/45/18
Fuel = BP Ultimate 98
Dyno Workshop = Bluechip Tuning, Sunshine Vic.
Date Dynoed = 2/5/07
Reason: Attached Sheet.
07-05-2007, 09:18 PM
Ride: VN Calais 5.0, UC Torana L67, WB Ute EFI 5.0
Blown V6 Hatch / Tim / UC Torana
HP (266.6 rwhp), kW (198.8 rwkW)
Engine Type and Capacity: 3800 V6 L67
Power Adders: Eaton M90 with 63mm pulley, Yella Terra Tower of Terra W2A intercooler, Yella Terra 1.8 ratio roller rockers, LS1 Throttle body, LS1 MAF, extractors, twin 2.5" into single 3" exhaust, K&N panel filter, Kalmaker tune.
Trans Type: M5
Diff Ratio: 3.55:1 LSD
Wheel/Tyre size: 15x8.5 with 255/60/15 BFG radial T/A's
Fuel Type: Mobil 8000
Name Of Workshop: Chip Control
Date Dynoed: 30/6/2006
08-05-2007, 06:05 PM
Ride: vy ss and vz sv6 ute
Highlander_69r / michael/ VY SS
HP (XXX.Xhp), kW (281.7kw)
Engine Type and Capacity: LS1
Power Adders: cam/tune/zorst/25%udp
Trans Type (M6, A4, etc): Hi stalled A4
Diff Ratio: 3.91
Wheel/Tyre size: 235/40/18
Fuel Type: bp98
Name Of Workshop: Hi Torque performance
Date Dynoed: 3/5/07
28-08-2007, 12:10 AM
Fear my Vee-Peeness
Ride: SV6 VP
pow3rslave / tim / VP v6
140.0kW
Engine Type and Capacity: 3.8 V6
Power Adders: wade 992a cam, heads shaved 15thou, crow heavy duty springs, rollermaster single row chain, k&n panel, VS SS CAI, Pacemaker extractors, twin cat>2.5 catback system.
Trans Type t5
Diff Ratio: 3.08:1
Wheel/Tyre size: 235 17"
Fuel Type: regular
Name Of Workshop: s&s racing
Date Dynoed: 30/07/07
06-09-2007, 08:34 PM
Blown Twin Throttle VY V6
Ride: VY S S2 M5
Still a v6
fmlycar / Kurt Schumann / VY S S2
HP (191.3hp), kW (140.7kw) (If you only know one, ill work it out for you)
Power Adders: Check my ride
Trans Type (M6, A4, etc): Getrag M35
Diff Ratio: 3.46 LSD
Wheel/Tyre size: 245/40R18
Fuel Type: 95 premium unleaded
Name Of Workshop: Street Torque
Date Dynoed: 01/08/2007
__________________
When you see a car that's BLOWN it's refering to the budget.
27-09-2007, 06:24 PM
No longer a commy driver
Ride: '96 Prado 4x4
xlr8_87 / Rob / VP
HP (181.6hp), kW (135.4kW) (If you only know one, ill work it out for you)
Engine Type and Capacity: Ecotec V6 (3.8L)
Power Adders: YT 1.8:1 rockers, ported/polished heads, twin 54mm throttle manifold, pacemaker extractors, custom mandrel bent 3" exhaust with hi-flow cat, pod filter
Trans Type (M6, A4, etc): T5
Diff Ratio: 3.08:1
Wheel/Tyre size: 205/60/15
Fuel Type: 98 octane
Name Of Workshop: Addicted Performance
Date Dynoed: 02/08/07
__________________
<<<Rob>>>
Ecotec VP, 135rwkw, 427nm
03-10-2007, 08:54 AM
Ride: VN SS..calais sadly sold
calaiscruzer/daz/ vn v6 calais
HP (165hp), kW (121.4kw)-
Engine Type and Capacity: 3.8l -VP s2
Power Adders: K&N filter, 2.5" redback exhaust, stage 3 cam, lifters,stronger timing chain, custom chip, 70mm throttle.
Diff Ratio: 3.08
Wheel/Tyre size: 235/35/19
Fuel Type: optimax
Name Of Workshop: Chasers Auto
Date Dynoed: 1/8/07
03-10-2007, 09:56 AM
Ride: VT Berlina S2 5.7
RavenLS1 / Jonathan / VT II Berlina
HP 322rwhp, kW 240rwkw
Engine Type and Capacity:Gen 3 346ci
Power Adders:mafless, MCAI, extractors, twin 2.5" exhaust,3"h/f cats,84mmt/b, u/d pulleys.
Trans Type : A4
Diff Ratio: 3.73
Wheel/Tyre size: 15" 225/60/15
Fuel Type: pump
Name Of Workshop: APS frankston
Date Dynoed:6/9/07
08-10-2007, 09:16 PM
Australia 1-Germany 0
Ride: VX Calais II LS1
Sphinx
Sphinx / Mike / '01 VX Berlina
HP (244.06rwhp), kW (182.0rwkw)
Engine Type and Capacity: LS1 5.7
Power Adders: MCAI, K&N filter
Trans Type (M6, A4, etc): A4
Diff Ratio: 3.08
Wheel/Tyre size: 225/50/R16
Name Of Workshop: G&D Performance
Date Dynoed: 8/10/07
http://forums.justcommodores.com.au/...rlina-dyno.jpg
__________________
LS1. Making others claim they missed a gear since '99.
09-10-2007, 12:42 AM
VP nut
Ride: VP Ute 3.8T M5
LowVp / Dru / 93 VP ute
HP (254.rwhp), kW (190.9rwkW) (If you only know one, ill work it out for you)
Power Adders: Turbo and associated gear
Trans Type (M6, A4, etc): M5
Diff Ratio: 3.45
Wheel/Tyre size: 235/45/R17
Name Of Workshop: Competitive Autogas
Date Dynoed: 6/9/07
11-10-2007, 02:43 AM
Enhanced Automotive
Ride: TWIN TURBO VY SS-FORGED LS1 505RWKW
enhancedss / Brad / VY SS
HP (XXX.Xhp), kW (475.XkW) (If you only know one, ill work it out for you)
Engine Type and Capacity: 5.7 LS1
Power Adders: Twin Turbo, to much to list.
Diff Ratio: 3.46
Fuel Type: BP Ultimate
Name Of Workshop: Enhanced Automotive
Date Dynoed: 29/09/07
__________________
www.enhancedautomotive.com.au
LS1,LS2,L76 & L98 PERFORMANCE TUNING
VN/VP/VR/VS/VT/VX/VY/VZ PERFORMANCE TUNING
CAM & HEAD PACKAGES
SPECIALISING IN FORCED INDUCTION
Enhanced Automotive
(08)8250 2233
11-10-2007, 10:08 AM
Cant Pretend
