ecu pinout
ryan1980
VN
anyone got an ecu pinout for a vr commodore auto?
i just need to know which wire goes where/triggers what!
thanks!
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
i have LOL...if you need help with anything ive just been messing with vr auto ecu too VN 808 ecu/VR manual ecu so pretty much know whats what
ryan1980
VN
cool well i need to know which one's the tacho signal wire. I've done an engine transplant into an old bmw and i want to try get the factory tacho going!
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
well the tacho doesnt come from the ecu its straight from the dfi its marked in the diagram i posted goes straight to the dash
ryan1980
VN
whats the dfi look like and where would i find it?
what colour wire is the tacho one?
diagram is hard to read!
VZ V6 One Tonner & LX SL/R 5000
The DFI (Direct Fire Module) is also commonly known as the coil pack.
The Tacho wire is brown.
ryan1980
VN
thanks mate
think i found the wire but im buggered if i can get this tacho to work , lol
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
there should be a little sprout hanging out the harness near the dfi module try connecting the tacho too that might be green or brown cant remember off hand
It's the same wire spliced in parallel. Used as a test point.
ryan1980
VN
oh yeah its green. Doesnt work though, i think it may be because the bmw tacho is different to the commodore one.
buggered if i know
