+ Reply to Thread
Results 1 to 4 of 4
Thread: starting problems vs
    vs 3.8
    Jun 2009
    Default starting problems vs
    Replaced starter motor two days ago, been ok up till last night. When I try to start the car now, I only get a click from the solenoid. Charged battery overnite, but still the same thing this morning.
    Any clues where to look????
    thanks
    Brian
    holdenboy's Avatar
    holdenboy is offline Custom Car Stereo Systems holdenboy Calais
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Check that the battery terminals are clean and on tight, also check the main wire on the starter motor, it may have come loose.
    150db in a commodore =
    VS Ute
    Jul 2009
    Question VS Ute engine will not start
    Came home a couple of nights ago, next morning engine will not start. Checked Battery (recharged), checked terminals (OK), checked for spark (OK), - yes fuel in tank. Motor turns over just fine but does not fire up. There is a clicking noise coming from under the cowling on top of the motor when you turn on the ignition, lasts for 2 or 3 seconds then stops. The same noise sounds for about 5 seconds when you turn the ignition off again - not sure if this means anything. Any Ideas?
    vnv6
    Jan 2009
    Have you removed the alternator at all ?
+ Reply to Thread
  1. starting problems
    By hydratrac in forum Electrical Wiring / Questions
    Last Post: 16-07-2009, 11:03 PM
  2. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 03:55 PM
  3. Starting problems
    By Emu in forum General
    Last Post: 23-10-2006, 09:11 AM
  4. Starting problems with VS!Can u help?
    By vsbakkie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-08-2005, 07:35 PM
  5. VT SV6 starting problems
    By geebee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-08-2005, 07:43 AM
