Probably common but.................she wont start cranks well then tries too ,then coughs, not good has been running rich shop recommends changing engine loom. This sounds drastic, was on gas but gas off now.ps all advise will be appreciated
check fuses also check and if needed change rear fuelpump
Is your fuel pump operational? Do you have fuel pressure at the rail? Do you have spark?
Do you have fuel?Ha ha, many a car comes in wont start..chuck some petrol in and amazingly it goes. :P
i'm sure this fella is going to be exhilarated to have his car going again after 4 and a half years of been off the road
