Kurtp
VR Buicks > You ;)
- Aug 6, 2009
- 182
- 3
- 0
- Location
- Pakkey VIC
- VR Series 2 V6 Sedan
EDIT: Ive written up a load of ways ive tried and discovered along my path to fixing alternators Check out newest post. (scroll down) and solved mine, wire from back of alternator to battery completely corroded, Cu2+ ions shitting all over the wires all over the place. Can't be good. Replacing wire.
Hi guys,
Have a weird problem with the Alternator in my VR, Randomly while driving the light flickers on and off, sometimes it holds for a while then goes off. Originally we thought it to be the brushes which we changed, but it still continued to happen. The car has had no problems with power and always started and seems to charge fine. One thing ive noticed however is when driving at night when the light comes on, all the lights dim slightly, then instantly get brighter again when it turns off. Not sure what it could be, thought maybe a loose wire? if so where would i need to look?
Hi guys,
