+ Reply to Thread
Results 1 to 6 of 6
Thread: VP 5lt instrument cluster reconnect
    customute Guest
    Default VP 5lt instrument cluster reconnect
    Hi. i been rebuilding a VPs93 5lt Ute from scratch for about a year now and it's coming close to be finish.I'm now about to reconnect the instrument cluster to the 3 differents plug/connectors and cant remember which way to fit them. I got the plugs order right just need a bit a help in the wiring connectors plugs parts as i can see that they can fit other up or down but i dont want to do the wrong way and burn out the instrument cluster.Many thanx for you answer.Great website !!
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input.... Tasmaniak Executive Tasmaniak Executive Tasmaniak Executive Tasmaniak Executive
    car
    Apr 2005
    ummmmmmm they shouldn't be able to go anyway....One side has a clip and the other side has a slight ridge for the clip to grab onto.....??
    customute Guest
    Quote Originally Posted by trunkrattler
    The connectors are not going anywhere, i'm just unsure the right way to fit the instrument cluster, as there is two possible way : up and down, as the connectors look like a rectangles with a litle bit of plastic in square form in 1 corner.there is orange plastic around 2 of the connectors and 1 blue.Hope u can still help me with my explanations.Thanx a lot again for you help
    Tasmaniak's Avatar
    car
    Apr 2005
    Are you able to post up some pics at all?
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Heres the layout with the colours taken from info of the factory book...a few colours might be missing but you will get the idea as most are correct and you will see how the instument connectors are installed .They are in order as you see them in the dash.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    customute Guest
    Quote Originally Posted by markovr
    Thanx a lot all good now
+ Reply to Thread
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 01:41 PM
  2. instrument cluster
    By invasion in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-12-2008, 03:48 PM
  3. Instrument cluster
    By Fu Manchu in forum Electrical Wiring / Questions
    Last Post: 06-04-2006, 07:53 PM
  4. Instrument Cluster
    By Stewart1000 in forum Electrical Wiring / Questions
    Last Post: 17-11-2005, 05:41 PM
  5. Vt Instrument Cluster
    By Naccas in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-11-2003, 11:06 AM
